Class D technologies
gjm
I have done a search, and looked beyond that, but haven't found a detailed discussion of the different tech that can e used in creating a Class-D amplifier.
Not the circuit topology, or a Class D vs Class A consideration... Just the type and source of tech.
  • Hypex
  • ICEpower
  • Purifi
  • Pascal
  • Powersoft
  • Anaview
  • Starkrimson
  • Others...
What are the merits/disadvantages of each? Is it possible to discuss this without diving into detailed technical specifications? Is there a hierarchy or is that entirely dependent on the implementation and associated design?
MakeMineVinyl
Santa Fe, NM
You're asking for reams of information. Google search is your friend. ;)
AdamG
Moderator
Reality
Start here: Much thanks to our resident Expert @DonH56
Then use the search function “Class D” and start reading
Sokel
How each implementation translates into real world performance,durability,price,etc would be much more useful to the end user.
Experts here will know exactly how to guide us away from hype,etc.
Reactions: gjm
voodooless
Netherlands
Sure, here is one:
  • Anaview
  • Hypex
  • ICEpower
  • Others...
  • Pascal
  • Powersoft
  • Purifi
  • Starkrimson
There are many metrics that you can sort amps by: cost, power, size, noise, distortion, etc. Many of your examples have various models that are not even the same in terms of general performance, cost or power. So it gets complicated very fast. Best to just check out the reviews with decent measurements to see how these amps stack up.
SIY
Alfred, NY
This question can maybe be answered by class D experts here at ASR. What are the best class D implementations and then go down from there.
There is no "best," just good ones and crappy ones.
DonH56
Monument, CO
What does "type and source of tech" mean? You say "not circuit topology"; most of those amps use similar devices, but differ in circuit topology, most likely proprietary to the manufacturer. As others have said, any hierarchical ranking would depend on what metrics you choose and how you weight them. Any question along the lines of "What is the best xyz?" must be highly-qualified with the application and other parameters (such as power, price, size, etc.) to narrow the scope of the question. The "right" answer is usually very specific to the user.
How high is up?
FWIWFM/IME/IMO - Don
greenid
Washington, DC
Found ASR this evening and having read many of the comments about the "Class D Revolution" - I'm excited to make the switch.
Is there an opinion of which of the manufacturers (or implementations) holds their value? Would seem Apollon is leading the pack and the Hypex 502MP is a no-brainer for the price performance.
FWIW - I'm driving Tannoy Precision 6.2s with a Rega Brio amp and they seem underpowered.
aaddas
Saudi Arabia
My recommendation do not go far,
For music >>> integrated amp class ab
For movies >>> NCX500 class D
DVDdoug
I don't know anything about those, but how does the amplifier power compare with the speaker's power rating?
Note that double the wattage is only 3dB louder. That's a "noticeable" difference but probably not enough if the speakers are underpowered now. +6dB (4 times the power) may not make a big enough difference for you.
Speakers are supposed to be "safe" with an amplifier that's putting-out program-peaks at the speaker's rated power. i.e. As long as the amplifier doesn't put-out more than the speaker's rating, you should be OK as long is the amplifier isn't clipping, or only very-occasionally clipping. It's probably OK if the amplifier has a little extra power but be careful, since you seem to be complaining that it's not loud enough.
The "sound quality" of most solid state amplifiers is very good (as long as they are not over-driven into clipping/distortion). If there's an issue it will probably be noise. All analog electronics generate some noise and some amplifiers are noisier than others. And the more efficient/sensitive your speakers are, and the closer you sit to them, the more likely you are to hear noise.
Galliardist
Sydney. NSW, Australia
It appears that the lowest effective impedance of the Tannoys is too low for the Brio to drive.
Additionally, I remember issues with the Brio’s pre-outs and some power amps being raised in the past. I think the issue was low gain.
A decent Hypex or Purifi power amp should get you going, but it’s a good idea to check compatibility. Personally I’d replace the Brio completely. Budget is obviously the issue at that point.
What are your sources? Room size and listening distance? Would different speakers also be in order here?
