If you would point them out, I could fix them. So far here, I don't see bugs, I see incorrect use of the software.DW has bugs.
Incorrect settings, I suspect.I get -60-something without matching (just "Show" button) and -80-something with matching ("Match" button).
These are mono files. Weird that there is a difference in correlated null and jitter shown in the status at the bottom.
I get the same values both for L and R but different than yours
(@pkane ?)
For me it was the "measure simple waveforms" that messed it,it was left there after I did measured simple waveforms couple of days ago and prompted me to engage it.Incorrect settings, I suspect.
-80.5dB is the null if you use these (all linear) settings:
Yes, that setting is not meant for music but for simple periodic test signals, like a single frequency sine wave.For me it was the "measure simple waveforms" that messed it,it was left there after I did measured simple waveforms couple of days ago and prompted me to engage it.
I though it would reverse the setting after and I didn't check it![]()
I get unpredictable single sample drift, like shot noise, probably depending on processor load. This happens in this test with DW, but never with Adobe Audition direct subtraction. The drift of the single sample is more than 100 LSB levels high. Sounds like a click, which is non-existent in the test files.If you would point them out, I could fix them. So far here, I don't see bugs, I see incorrect use of the software.
There is a discontinuity in both files:Sounds like a click, which is non-existent in the test files.
Mostly the same here with the exception of "correlated null":Null of -80dB:
My frequency response looks slightly different:No issues with phase or frequency response:
I am talking about file difference, and there is no discontinuity in the file created by subtraction. So I am asked to go to AA and show the amplified raw difference?? You guys better post your ABX protocol from 16 trials, that is the thread topic! Stop speculations, please.
Those are the settings I used and I see Paul, Sokel and myself had the same result out to 2 decimal places.Incorrect settings, I suspect.
When I used Deltawave the difference file has a click when amplified at that 41.3 second point where the discontinuity is. When I do a straight subtraction in Audacity it is still there though more of sharp thump than a click. When I do this in Reaper it is a thump like in Audacity.I get unpredictable single sample drift, like shot noise, probably depending on processor load. This happens in this test with DW, but never with Adobe Audition direct subtraction. The drift of the single sample is more than 100 LSB levels high. Sounds like a click, which is non-existent in the test files.
Now if I turn off "Correct clock drift" and "Subsample Offset" in Deltawave then I get the thump like in Audacity and Reaper doing straight subtraction. The null is less good being only -63 db instead of more than -80 db.
@pma @pkane
Interesting. I am getting this from Adobe Audition, as a direct subtraction. Where do I see the discontinuity? But yes, I did not try to download the uploaded files, but I am checking my originals in the PC.When I used Deltawave the difference file has a click when amplified at that 41.3 second point where the discontinuity is. When I do a straight subtraction in Audacity it is still there though more of sharp thump than a click. When I do this in Reaper it is a thump like in Audacity.
@pma @pkane
I think if you'll listen you'll hear it. It is not as easy to hear as the click, but is definitely there.Interesting. I am getting this from Adobe Audition, as a direct subtraction. Where do I see the discontinuity? But yes, I did not try to download the uploaded files, but I am checking my originals in the PC.
