DaneelOlivaw
- Joined
- Mar 21, 2025
- Messages
- 28
- Likes
- 12
I did now my first steps with ABX plugin. I tried with the "Fast Car" sample which i was not able to hear differences before. But with ABXVery interesting initial pattern.
01/01
02/02
03/03
03/04
... exactly the same as mine ...
I was pretty sure I could hear the difference ... especially the initial clapping (more air in one track) ... and one had sharper "ess" in the female vocal ...
For me, I donno if fatigue/boredom set in after that, it just went downhill after 4-5 tracks for me.
Question for you ... after the initial 3-4 tracks ... did boredom/fatigue set in for you? Or you were all ok to the end of the test? I'm just curious ...
I think I heard that the Hi Hats sounded slightly different right at the beginning.
The longer i tested the more it sounded quite similar to me.
It was not better or more detail but like you turn your speakers silghtly to a side. Maybe a delta check only from the hiss sound in this fraction of a second might be interesting.
And using ABX you should have a break each time after 4 comparisons.
Default : Lautsprecher (SABAJ USB DAC) [exclusive], 32-bit
Crossfading: NO
12:39:22 : Test started.
12:39:37 : Test restarted.
12:39:37 : 01/01
12:39:45 : Test restarted.
12:39:45 : 02/02
12:39:53 : Test restarted.
12:39:53 : 03/03
12:40:39 : Test restarted.
12:40:39 : 04/04
12:41:09 : Test restarted.
12:41:09 : 05/05
12:41:22 : Test restarted.
12:41:22 : 05/06
12:41:31 : Test restarted.
12:41:31 : 05/07
12:41:38 : Test restarted.
12:41:38 : 06/08
12:41:38 : Test finished.
Total: 6/8
p-value: 0.1445 (14.45%)
-- signature --
d6190de6b1a46df10e781f31c763d3aeccf91beb
