So is the concern that signal A has passed through X number of devices vs signal B the same X plus a mediocre DAC so because of that you can't compare A vs B because of these X? Why couldn't we do that?
The device is basically a microphone A/D converter (makes sense to use one to create videos like he does). He lists links for EVERYTHING he uses for his videos. Teleprompters, microphones, monitors. Even what he uses for hair care. No link to say device he used for the "test". You are making assumptions. The questions is about equipment used. The video author makes no mention (except your "link") is being ambiguous at best, even when faced with a direct question in the video comments, the author does not answer. Perhaps ambiguity is his intention, if for aything but to generate activity such as this thread.
I understand blind A/B testing and the principle behind it.
But as a music listener, this test is irrelevant. If the goal is to point out "you cannot tell the difference between DACs" then it is pure BS depending on what you call a "DAC". I am not going to be listening to music through a mic A/D converter. And of all the two-channel "DACs" intended for music, take any two and you will probably hear a difference (design and gain stages make a difference, chips? no so much, but I have had my share of "bad" sounding "DAC" purchases). This is what I suspect MOST on this forum are interested in. Not some 48+Khz sampling pro audio device.
No offence or insult taken. It is just irritating that so many assumptions are made based on a post of two or three sentences (and how "new" I am to this forum). Attempting a broader view/understanding of the world may help (no gaurantee), but I am not here to give advice.
In any case the video is useless as far as I am concerned.
So there are 2 digital files. 1 original and one that went through cheap DAC/ADC process.Can you tell the difference between an original Abbey Road recording and that same recording through a mediocre DAC?
So for you the video is pointless because you either did not understand the test or it is pointless because you could not hear a difference so it is 'trickery'.
That's like; ”I don’t believe my arthritis diagnosis because we don’t run in MRI scanners”.
Not in a proper blind test:And of all the two-channel "DACs" intended for music, take any two and you will probably hear a difference
www.audiosciencereview.com
The evidence strongly suggests otherwise, as I have repeatedly pointed out, with links. And you still don’t have your facts straight about the test in question, as amply demonstrated above.And of all the two-channel "DACs" intended for music, take any two and you will probably hear a difference (design and gain stages make a difference, chips? no so much,
Given that his test was trivially easy to cheat, I'm not sure what is self-fulfilling here.The whole thing is flawed and the opposite of a blind test, it´s a self-fulfilling scenario.
We can check if he did something. And yes, he did and switched forth and back six times, as he said:Here is the thing ... we have to trust the guy that what he said he did was what he actually did and was not out to trick people and either did not switch or he just loaded 2 original files in his DAW but simply renamed one pretending to have gone through cheap DAC-ADC.
This complaint would only make sense if you also claimed that audiophiles typically use much worse DACs than the one he used. Is that what you say?So we still do not know this mystery device he used for the test. Or if it even resembles a typical DAC an "audiophile" would use to listen music. We just know that is cheap and on amazon.
Wish I could like this twice.When you don't hear the changes then there are three explanations (one of them not really serious):
- His cheap DAC and ADC introduce so little distortion that the changes are below audibility. Therefore the DAC --> ADC steps are transparent. Therefore his cheap DAC on its own is even... er... transparenter
- Your DAC (presumably good) is in fact really bad and the distortion it introduces, hides any changes introduced by his cheap DAC and ADC.
- (not really serious) His DAC introduces big changes but his ADC somehow magically reverts them.
clear evidence, mostly added noise by the DAC-ADC loop.We can check if he did something. And yes, he did and switched forth and back six times, as he said:
Good job. Thanks for showing what the music file looked like.Given that his test was trivially easy to cheat, I'm not sure what is self-fulfilling here.
When you listen to the file he provided then what you compare is:
to:
- the original file --> your DAC (presumably good) --> your ears
- the original file --> his DAC (cheap) --> his ADC (cheap) --> your DAC (presumably good) --> your ears
So which one is it? (I know, "He didn't use the music I like")
You should be able to see the positive in the fact that you can't hear any differences. I mean, hurray now I don't have to buy that extremely expensive DAC, those cables that cost like a car, those ...choose whatever nonsens...to get that superb sound and can instead spend my HiFi money on what really matters; speakers, room acoustics, EQ and amplifier (modern sensible with a decent amount of power vs low powered high end tube amp).Wish I could like this twice.
There are other explanations - the switching is faked/it’s a better DAC. But, whatever.
I have long maintained the fever over the extreme prices charged for some DACs to be just that...a fever and one that affects ones common sense and clearly ( to me ) most of the fuss over a $30k Dac vs my 329 Wiim is just people wanting it to sound better than my humble $329 Wiim because they paid more, but my ears cannot perceive any difference listening to the file you played to determine whether you switched between the loop-back version and direct version even once...not by just listening. With sophisticated measuring equipment I bet that I could, but I could not hear it. I consider myself a trained and refined listener, but at the end of the day, there is so much noise about such minute differences in sound quality that the price differential is huge. And to my practical mind and limited pocketbook the expensive gear is so much more about bragging rights than actual sound quality. I am delighted with my Wiim streamer DAC. And I may buy a second one for another location in my home. Its that good. I see no reason to spend more.It was good. Well done with music files to download. Check out the first video regarding the test:
Screenshot above from this video:
Wiim has hit the bull's eye with its features.I have long maintained the fever over the extreme prices charged for some DACs to be just that...a fever and one that affects ones common sense and clearly ( to me ) most of the fuss over a $30k Dac vs my 329 Wiim is just people wanting it to sound better than my humble $329 Wiim because they paid more, but my ears cannot perceive any difference listening to the file you played to determine whether you switched between the loop-back version and direct version even once...not by just listening. With sophisticated measuring equipment I bet that I could, but I could not hear it. I consider myself a trained and refined listener, but at the end of the day, there is so much noise about such minute differences in sound quality that the price differential is huge. And to my practical mind and limited pocketbook the expensive gear is so much more about bragging rights than actual sound quality. I am delighted with my Wiim streamer DAC. And I may buy a second one for another location in my home. Its that good. I see no reason to spend more.
Until Hifi shows are reduced to hotels and conference centres replete with only the cacophony of pink noise blaring from listening rooms, the gods of snake oil will continue to reign there.Personally if I want to evaluate gear, I listen to pink noise and sweeps first. Whatever I'm listening for is easiest to find that way. If I hear anything in particular, I can evaluate the subjective effect on music once I establish it's not a piece of junk.
I used to go to trade shows and need to check dozens of speakers or headphones in a day, so we could find factories worth following up with. Test signals save a lot of time in that scenario.
"In real life", testing gear with music is mostly a waste of time. For hobby purposes or for writing flowery prose it's useful, but not if you just need to identify flaws quickly. Also, listening to the first 15 seconds of the same song 40 times a day isn't much more fun than listening to pink noise.
The reviewers use case is evaluating one piece of gear thoroughly, but for the buyer checking many systems against each other, pink noise makes it much easier. Not sure if they would let people play pink noise at a HiFi show, but they should.
So Douk Audio K5 is the cheap DAC in the test. A DAC with specs according to the manufacturer:Comparing two DAC - one for $120 one for $2,000 David Mellors new video is a must see!
Dear Gold Ears,
Another highly interesting comparison with beautiful, cleanly recorded sound samples. You can download the original files as ZIP files (96 kHz, 24 bit resolution).
It's hard to tell the difference!
David Mellor worked as a sound engineer at Abbey Road Studios for over 20 years. He knows what he's talking about!
doukaudio.com
Caution:David Mellor worked as a sound engineer at Abbey Road Studios for over 20 years. He knows what he's talking about!
omg, caro embro or whatever. pretty, that about it. i get annoyed with folks telling me i can't use edm because it's not discerning enough. if your gear doesn't sound good playing my music, im not interested.I'm fine with the test, but using more complicated music isn't just about "pedal to the metal", it's about exploring a much broader palette of dynamics and frequency where defects might be revealed.
I can't come up with the right search string, but I do believe @amirm has posted some studies showing how people hear differences with different kinds of music. What I remember is the summary: the girl-with-guitar stuff that everyone uses in hifi shows is not very demanding. Can't be much better when you subtract the girl.
