Can you EQ this with a compression driver?
DanielT
DanielT
Sweden - Слава Україні
The usual way is to NOT EQ, but to use a capacitor to roll off the response starting at around 8-10 kHz and that will reduce the whole region below it enough to make it mostly flat.
One cap, at a 6db/octave roll off.
It seems smart,
My XD125 FR:
Roll off with capacitor:
After that if needed EQ.:)
Two bipolar capacitors of around 2.0uF only cost around $2-4 thereabouts.
DanielT
DanielT
Some old analog crossovers had a button\jumper "CD EQ", where CD means "constant directivity" :)
Also new products apparently::)
"High-Precision Stereo 2-Way/3-Way/Mono 4-Way Crossover with Limiters, Adjustable Time Delays and CD Horn Correction"
"CD Horn Compensation
When a driver radiates into open space via a horn, its efficiency increases. Over the past few years, constant-directivity horns have gained widespread popularity, since they are designed to produce consistent dispersion over their entire frequency range – however, the higher the frequency, the lower the efficiency. To compensate for this, the CX3400 includes a switchable pre-EQ for CD horns that ensures a fl at frequency response, even before equalization is applied. This pre-EQ raises the signal gain by 3 dB at 3.5 kHz, which then increases by 6 dB/oct. up to 22.5 kHz."
Nothing I intend to buy. I just saw that it was there. That functionality.:)
Edit:
Although new and new, ..it's Behringer so it's probably some old construction that they (illegal?) copied in true Behringer spirit, I can imagine.:)
