Lord Victor
- Joined
- Apr 19, 2019
- Messages
- 143
- Likes
- 99
Spoiler: I'm looking for papers/objective measures, don't yet have them. This takes offset in subjective observation/experience.
I'm currently trying to decipher what properties of speakers or drivers, might be correlated with particular aspects of perceived soundstage - based on having heard certain speakers consistently perform well in this regard (fx. Dynaudio Audience 10), regardless of which room/setup they've been in, compared to other speakers.
Since "soundstage" is a nebulous, apparently bordering on inflammatory, term, I'll attempt to define specifically what I'm looking for:
1. Scale: Some speakers tend to create a stage much larger in scale (width, depth and height) compared to others - making the music/musicians sound "bigger" (possibly less defined imaging).
2. Localization: Some speakers are difficult to make "disappear" in the sense that its generally easy to hear that the sound is coming from them, and the staging tends to be smaller and collapse very easily if you move (fx. very directive ribbons). Conversely some tend to very easily disappear, making a stronger center image, and in general rarely calling attention to themselves - and these tend to retain this staging more when you move around, comparatively.
So I'm looking to make something which creates large imaging, and which sonically 'disappears' readily.
As mentioned specific speakers like Dynaudio Audience 10, Evoke, Special 40 and Contour 1.4 have had this property in my experience, consistently across rooms - being far better at this than the about 15 other speakers I've owned and more that I've heard. Only close contender might be an Infinity Kappa 6.2i series ii.
What little papers/documentation I've found about Apparent Stage Width, Toole and from various other literature lead me to think this might tie to the reflected sounds relation to the direct sound from speakers, and hence possibly relate to the speakers directivity - which as far as I cant tell is largely determined by the tweeter. My assumption being that off axis response being as close to on axis would be best. However looking at directivity plots of old Dynaudio tweeters, their off axis response appears to roll off significantly, albeit in a fairly smooth/consistent manner.
Beyond this I know the aforementioned Dynaudio speakers tend to be noted for their exceptional bass apart from the staging. It's been a suspicion of mine that to some extent bass output can psychoacoustically lead to a sense of things being "bigger" - thought that is even more guesswork/intuition.
In my current attempts I haven't found common FR components amongst the speakers in measurement.
I'm hoping anyone in here have any thought on objective parameters which might influence this, or know of research papers out there that discuss this, as I've been unable to find much so far.
