I'm playing with the thought of an automatic match based on the test on the bass section so below 1 kHz (at least). Of course, if implemented this has to be tested. By doing things automatic (so taking out the user interaction) a user might expect a perfect match. He may be disappointed with the resulting equalization by this automatic selection of an equal-loudness contour. But it could be very nice if it does work
Yeah this and the 0.5dB steps would make me very happy ! That's for sure!
Depending on the used volume the equalization needs to change according to some equal-loudness contour which is created for a specific genre (remember that the equal-loudness contour is "measured" with sines). In other words, an proper equalization has a static part (say sliders) and a dynamic part which continuously measures the played song and adjusts accordingly to genre, volume, equalization and set taste. Anyway, all the test tool can give is a selection dropdown box for creating the equalization. Equalizer APO (thus Peace) doesn't have any dynamic features for sound processing. It could have but it doesn't.
What I had to resort to is manually doing 2 different measurements: One being with maximum volume for immersive listening and one with half-way for quiet times. It would be so badass to do let's say 10 measurements and have a dsp or something adjust in between the ones based on the volume the sound is being played at (if the amp could measure the dB level listened to and send it back to the computer > Equalizer APO then this feature would technically be possible some time in the far far far future right ^^?
I know very little about audio still but came to wanting this from what I know about how displays are calibrated to standards that take into consideration the luminance in the room and how our eyes see light in different environments. Personally, I don't believe in the kind of adaptive eq Apple is doing that wants to adjust for genres and toward their own faulty frequency curve that also is not the same sock for every costumer. I'm a purist so I would like to listen to what after ear-conversion essentially would be flat listening at the right volume level. I have a feeling it's not linear scaling in regards to how our ear perceives bass and treble depending on the volume so a single EQ would technically not do it if one doesn't control for absolute volume (dB)? The mid-range I assume molds better to different loudness.[/QUOTE]
