Does low gain (12.8dB) bypass the input buffer?As it's name implies, the switch changes the gain of the amplifier. Low=12.8dB - Mid=20.8dB - High=27.2dB
If the input of the amp is 1.8 V RMS, it's output will be:
High gain: 41V RMS, i.e. 280W in 6 Ohm
Mid gain: 19.7V RMS, i.e. 65W in 6 Ohm
Low gain: 7.8V RMS, i.e. 10W in 6 Ohm
If the purpose of the gain switch is to adapt the sensitivity of the amplifier to the upstream component, it can also be used as power limiter as demonstrated above.
Or does it flow through the 0dB input buffer?
