Beta Test: Multitone Loopback Analyzer software
Grooved
  • Fixed an error when enumerating audio devices that don’t report their settings
Thanks @pkane , totally forgot to report this one since the first version, it was always showing the highest setting previously use, even after lowering the settings
pkane
pkane
North-East
One more update bringing this up to version 1.0.4:
Changes in 1.0.4
  • Added support for using the same ASIO driver for input and output
  • Added Harmonics display to the spectrum plot when testing with a single frequency
  • Added support for TIM-type test signals consisting of a combination of a square and sine waves
  • Added two Transient Intermodulation distortion test signals to the list
  • Fixed history plots not displaying properly when only a single test tone was recorded
  • Some minor clean-up of functionality and display
The key update in this version is the ability to use the same ASIO driver for input and output. Other features were added by request:
TIM test signal:
Blumlein 88
And I haven't even gotten around to using version 3 yet. Looks like all good additions/changes.
MC_RME
Same here, currently travelling. 1.04 looks like a big one. Exciting!
pkane
pkane
North-East
Version 1.0.5 is now available:
Changes in 1.0.5​
  • Added support for saving/removing custom test signals (+ and - buttons next to the test tone edit box)
  • Added additional metrics (frequency, THD, SNR, and ENOB) to a single-tone test result
  • Added current FFT window on the main display above the FFT size
  • Changed “Dirichlet” FFT window name to “Dirichlet (Rect)”
Added documentation on how to create custom test signals. Some examples:
MySine 123.56Hz
SMPTE 30/60/1k/7k/13k 4:4:1:1
MT_Test4 20/100/13k/13.1k/15k 1:4:1:1:1
SQT_Test3 sq:1000Hz/13kHz 4:1
The new metrics are displayed for single-tone test signals, as long as the "Display Harmonics" setting is enabled in settings:
trl
King of Mods
Iasi, RO
A bit confusing the ENOB, given the formula (source: Wikipedia):
36ec123dbd02e4ed5dafef30e90f58faecaa694a
; I was hoping to see something around 19.5...20 bits.
Also, the Amir was measuring a SINAD of 120...121 dB, not 123 dB, so maybe this E50 is a bit better?
pkane
pkane
North-East
The ENOB calculation you're quoting is for a full-scale signal (0dBFS). Multitone makes an adjustment for a test signal that was measured below the full scale. The adjustment is the ratio between full scale and the measured signal. In the above test this is about 3.5dB, which accounts for about a 0.6 bits increase in the ENOB.
Reactions: trl
Lambda
@pkane is it open source?
And how are the chances to get it running on Linux?
pkane
pkane
North-East
It's not open source. It might run on Linux with Wine, but I've not tested it this way. Some of my other software, such as DeltaWave, is usable under Linux (see here). Since Multitone uses the same libraries and has similar dependencies, there is a decent chance it might work, but no guarantees :)
trl
King of Mods
Iasi, RO
Thanks for the replay, Paul. You mean -3.5dB, right?
What about the THD+N of -123.1 dB instead of the -120 dB measured by Amir? Is it related to the same adjustment as above?
Hee
Hi!
Look at the device in the picture above, the sampling rate setting is different.
If the sampling rate is the same, td+n is lowered. (about 119.6td+n 2ch mode)
In a few days, I will compare this program with REW.
pkane
pkane
North-East
The ratio is that of full-scale to measured level, so it's actually +3.5dB. This is from an Analog Devices paper on measurements:
THD+N is also a ratio, but I can't say if that's the reason for the difference from the screen shots posted.
Reactions: trl
trl
King of Mods
Iasi, RO
REW and ARTA and all other software will show a worse THD+N when lowering the amplitude of the DAC.
However, I am still puzzled about the above measurement, as DAC was running at full amplitude and the -3.5 dB is a result of the analyzer scale being different. I would day that FullAmpl/InputAmpl should be a negative number, like (0dBFS/-3.5dBFS), unless I'm on a completely different wavelength. :)
pkane
pkane
North-East
It's not a ratio of dBs -- dB is already a ratio. For example, if full scale amplitude is 4v and actual measured value was 2.67v. The ratio 4v/2.67v expressed in dB is 20*log(4/2.6) = +3.5dB.
In terms of ENOB, if the measured signal amplitude is less than full scale, noise floor remains at the same, but the signal is lower. Therefore, full-scale ENOB is going to be measured as a smaller number than the circuit is capable of and needs to be adjusted up.
Reactions: trl
pkane
pkane
North-East
Multitone version 1.0.7 is now available with some enhancements and bug fixes:
Changes in 1.0.7
  • Added: Click or right-click on the FFT Window name in the main display brings up a choice of available windows; no need to go to the Setup screen to change these
  • Added: Multitone maximum frequency setting is now also used for square an triangle wave generator, allowing for the test signal harmonics to exceed the Nyquist rate
  • Changed: Settings window frequency rates and dither bits can now be entered directly by typing them in, enabling the use of new values that are not in the drop-down list
  • Fixed: the Waveform plot legend had the Recorded and the Test signals swapped
Changes in 1.0.6
  • Added an additional pass of crest factor optimization to Multitone generator
  • Crest factor is now displayed for all test waveforms
MC_RME
Absolutely amazing. Congrats, Paul. Your work is going to set a new standard in multitone generation and analysis!
trl
King of Mods
Iasi, RO
trl
King of Mods
Iasi, RO
D90MQA on Cosmos ADC measured with REW and external 1 kHz via foobar
SINAD: 119.9 dB
D90MQA on Cosmos ADC measured with ARTA and external 1 kHz via foobar
SINAD: 119.2 dB
D90MQA on Cosmos ADC measured with ARTA and built-in 1 kHz signal
SINAD: 104.8 dB
Couldn't use WASAPI, perhaps something related to my laptop. However, using ASIO for Cosmos did the trick
Using higher FFT takes some time, wondering if Multitone can be optimized for more cores, please?
Thank you so much in your effort and time in deveopping this great application
Now the innevitable Q&A :) :
- How can I get multitones startng from 0 dBFS, to show the total dynamic of the device while playing multisines?
- Can you please let us run the show via external audio source? Basically, I'd like to run at least the 1 kHz test with my WAV file test.
Thanks again,
Raul.
pkane
pkane
North-East
SINAD: 119.9 dB
SINAD: 119.2 dB
SINAD: 104.8 dB
Thanks again,
Raul.
Hi Raul,
Thanks for testing!
I'm not sure if you mean Dynamic Range or something else? I didn't implement noise measurement with multitone signals yet, but this is something I plan on adding. This will allow DR and ENOB to be computed from any of the test signals.
That's doable with a single sine test signal. Multitone or other complex signals are harder, as it would require finding all the peaks. It's also doable, but accuracy of such calculations might be affected.
  • The poor TD+N (104.8dBFS) value in your screen capture above appears to be noise-dominated, with low THD. I'd check why noise was so high in that test.
  • Larger FFT does take a bit longer, but usually this should happen only the first time you use that size FFT on your computer. Multitone spends some time the first time to optimize for new FFT size, but should re-use the results from that optimization the next time. The FFT itself does use all available cores (or as many as it finds are useful for that specific FFT size).
  • The WASAPI error that you posted is usually due some other device controlling WASAPI driver at the same time in an exclusive mode or with a different sample/bit rate than what Multitone is set to record.
Let me know if you had other questions from the screen shots you posted.
Reactions: trl
