Hello everyone - Long time reader and first time poster here.
I understand the idea of matching playback sample rate to source sample rate when listening to a single source, but what about when there are multiple sources and the Windows 10 resampler is doing sample rate conversions?
Is there a general consensus on what playback sample rate would be best while listening to multiple audio sources in shared mode (e.g. Spotify + Discord + Game audio)? Correct me if I'm wrong, but while choosing 44.1khz would be optimal for Spotify, it would likely be sacrificing Discord and Game audio to some degree since those are typically 48khz sources.
Since my DAC supports sample rates up to 384khz, would it be better to upsample to a higher rate? In my research so far, I have seen some evidence (e.g. https://www.audiosciencereview.com/...indows-resampling-not-actually-that-bad.9092/) that the Windows 10 resampler performs a cleaner conversion from 44.1khz to higher up multiples of 48khz rather than 48khz itself. Could this be a good middle-ground sort of solution, since a multiple of 48khz would work well for any 48khz source?
With the above in mind, it seems reasonable to conclude that choosing a sample rate of 384khz would optimize 48khz sources while also making best use of Windows 10 resampler for 44.1khz sources, and 352.8khz would do the reverse, in favor of 44.1khz. I could simply choose one of these top two sample rates depending on which sources I want to "optimize" for. Is there anything I'm missing here?
