Nope, my statement was absolutely correct, as written, and yours perhaps has some errors.
Most engineers forget that impedance has a frequency term to it:
the jwL and jwC terms dominate at high frequencies and the cable, within the limits of the frequency linearity of the capacitance and inductance reaches an asymptote. For practical purposes that typically happens from about 5K - 50K. For most cables, the impedance is highly variable (as per the equation) at audio frequencies and hence is impossible to "match".
W.R.T. to most simplifications of where transmission line effects have effects, they are just that, simplifications. The ones w.r.t. it only mattering if the cable is > 1/10th or 1/20th the wavelength is just one of those simplifications and has been around from the days of long telephone and telegraph wires where the SNR was <40db, and stayed around into the digital era where again, 40db would be for most applications more than sufficient.
At 3m, limiting the bandwidth to the audio bandwidth, 20-20KHz, even at a -160db scale I do not think you will measure a difference. At a 100K bandwidth and 10 meters you may. I have done the calculations before, not worth doing them again
