dosifey
- Joined
- May 26, 2022
- Messages
- 90
- Likes
- 17
Hi,
I am utilising Nvidia Shield USB Audio output.
I am a big Kodi fan, as evertyhing works perfectly there from UI perspective: no need to sideload, it is very easy and quick to control it via remote, it plays my movies, music and even family photos and videos, it uses album art correctly and handles cue files. It works like a swiss clock.
However, I found one annoying problem there: it uses the Android built in USB audio drivers. So, when using that you have two options on Nvidia Shield: you either downsample all files to 16 bit 44100 Hz and then it works fine, or, you could upsample to 192/384Khz (random choice) and 24 bit with digital artifacts (clicking noise) as my DAC is only 24 bit 96Khz capable.
The latter option is absolutely not acceptable, first option is just bad. Why would you downsample 16 bit 48000 Hz audio files to 44100 Hz? It makes no sense! Of course, my hi res music recorded and stored in 24 bit 96000 Hz is played downsampled which is a joke.
So, I tried the usb audio player pro... There is no way to trial it, so I had to buy it to try. After using it for one day I am almost ready to uninstall it although I paid money for it. It's interface is almost not usable on Android TV. Very awkward control by remote, poor UI, multiple prompts popping out every time you start the Shield or player...
Is there any way to have the best of both worlds? No unnecessary up or downsampling while also having a usable UI?.. Even then, I guess I would have to live with downsampling of video files as there is no video player capable of maintaining sampling via USB audio...
