Holmz
It is possible that two DACS with identical performance against tones could sound different with music, as there are also a variety of filter schemes used for high end that could affect transient response.
Frequency response is the opposite side of the impulse coin. So I would say no. If the filter effects the FR, then maybe, but mostly due to FR.It is possible that two DACS with identical performance against tones could sound different with music, as there are also a variety of filter schemes used for high end that could affect transient response.
Further, our perception of the musical 'transient', is based on the ramp up of the envelope (volume) of the frequency. I looked in detail at the "transient" of a cymbal. The strike section had a fundamental of around 8kHz, and the envelope ramps up over about 1ms (so about 8 to 10 cycles of that frequency).'transients' in music are mostly in the 2-8kHz range and none of the filters is 'active' in that band.
Perceived 'transients' in music is not the same as 'transient' response as it is known in electronics.
Yes. I am well aware of the trap that is expectation bias. I have written much about on a defunct hifi forum. I realize that EB can't be turned off, ever. It's always there at work. The best one can do is to be aware of it.
I am all too aware of my own expectation bias. That is why I ask the question of myself. I remember very well all the time wasted thinking I could hear a difference in a sighted listen.
So a $10 DAC that isn't broken, measures sufficiently well, and is level-matched will sound the same as one costing thousands.
The one who made the assertion didn't say anything about measuring sufficiently well, nor be level-matched. But I can go along with it as added qualifications. So if your qualifications are met, do all DACs sound the same in your opinion?
...and some who run away when their beliefs are put to the test. I'm thinking of a recent one in particular...We occasionally have members who actually want to put their ears to the test
...and some who run away when their beliefs are put to the test. I'm thinking of a recent one in particular...![]()
Yep, there is nothing 'instant' or 'fast' about it.Further, our perception of the musical 'transient', is based on the ramp up of the envelope (volume) of the frequency. I looked in detail at the "transient" of a cymbal. The strike section had a fundamental of around 8kHz, and the envelope ramps up over about 1ms (so about 8 to 10 cycles of that frequency).
Using a Chromecast Audio, I experienced a clear and well-defined center image, identical to what I get with the Wiim Pro Plus and my low to mid-priced Sony CD player from the nineties.No. You hear it. Maybe im using the wrong term but the center was never the clear, resolved center with the topping but with the denafrips the center of the image is solid. You hear the sound clearly right in the center.
And it wasnt a matter of immediate comparison for this problem. It was always there and bugged me with the topping no matter what i did with my speakers. Bought the denafrips for a good price locally and the problem was gone.
It kind of is, though. As you know, someone raised the ante on my $10k challenge and I started thinking about a bulletproof way to test his Chord against my Topping (although he wanted the cheapest dongle in our review section). Level-matching and blind instant switching are a bit of a challenge*, and I realized I would have to make investments I didn't want to make.Too much trouble?
Can I ask for a link? I think I missed and it sounds like it could be entertaining...and some who run away when their beliefs are put to the test. I'm thinking of a recent one in particular...![]()
www.audiosciencereview.com
Same. Had my son swap cords on amps, compared DACs carefully. Did some online tests, read some of the tests and literature online, and that was it.That's pretty much what I did, and I think many of us have done, and never really needed to go through it again. I looked at the entire industry differently afterwards.
No. If the "filter schemes used for high end" affect transient response in an audible way, then they will also affect frequency response in an audible way (no longer "identical performance against tones," to use your words).
It is too much trouble and not needed in my case. I'm not a hobbyist. I just like listening to music. I've bought what I consider to be the best kit available (almost), and set it up very precisely. That's good enough for me. I'm very satisfied with my hifi system, and I listen practically every day.No, the best one can do is control for it with level and sight controls as a starter.
Then why do you not bother with some basic controls? We occasionally have members who actually want to put their ears to the test as in the thread linked below, but most can't be bothered.
Post in thread 'Blind testing two DACs - Proper Process' https://audiosciencereview.com/foru...ng-two-dacs-proper-process.57890/post-2118881
Too much trouble?
I do too, but that is different from asserting, improbably, that one can hear differences between electronics that measure as audibly transparent.It is too much trouble and not needed in my case. I'm not a hobbyist. I just like listening to music. I've bought what I consider to be the best kit available (almost), and set it up very precisely. That's good enough for me. I'm very satisfied with my hifi system, and I listen practically every day.
I don't read nor participate in the discussions much. I mostly enjoy Amir's reviews.
I've heard a $5k system that I preferred over a $100k+ system. How would one measure performance objectively?
If one likes the sound of the expensive kit more than a less expensive piece of kit, then they may be willing to pay the extra to get the sound that they prefer.
There may very well be an expensive DAC that can't be matched by a cheaper DAC. I don't know. I just enjoy listening to music at home. This is where the hifi system performs.
