wadude
A slight change then: Tubas don’t make music, people make music…with tubas.True enough, if we use the term "music" as it is traditionally used. That's why I wrote that a musical instrument is a technical device for creating sound/music. As far as I know this is how "musical instrument" is usually defined (ref. Encyclopedia Britannica, Wikipedia etc...). Nowadays, a computer running a suitable AI software and connected to a suitable electronic musical instrument could be said as being capable of making music.
A Theremin is a musical instrument, but a tube inside the Theremin is not. To create a sound with that tube, One has to take it away from the Theremin and use it in a "MattHooper-instrument".
As for AI, since the software itself is probably not inspired by a Muse, the sounds created might be come to be considered something other than music. I wonder if our human sensitivity to music will evolve enough to immediately recognize the difference? Interactions with AI receptionists on the phone and using Siri don’t feel human, but they are effective ways to handle those types of transactions.
One early example of mechanically generated music is Brian Eno’s, Discreet Music (1975), although he did create the initial motifs on tape and then let them loop.
