I have to chime in with a shout-out to my current favorite portable amp, actually a wired/wireless DAC/amp: the Radsone EarStudio ES100.
Even if you have ample power/resolution from your 3.5 mm source output, EQ options run surprisingly thin. We’re not talking the power levels of the review units in this thread, but you can clip this on your shirt and go. I regularly hook it up to my HD 650s, when I’m at home. Feels like winning. I can also compensate for China-market-oriented tunings of FiiO IEMs.
Listening to the Live From Here broadcast right now on my iPad>>ES100>>FiiO FA7 on AAC Bluetooth. Not bad.
I have one but been stuck in not having a convenient way to profile its Bluetooth. If you want to know its perf with USB and sample BT codec, I can do that.I've been very curious about the Earstudio. Now, just clip or velcro it to your HD650 headband and make yourself a mini cable. Now that would be fine.
Ref to 1V?I measured signal to noise ratio but the data is junk because both devices severely clip at maximum level which is what is used for determining SNR:
<snip>
I need to devise better test parameters here.
Wait - the O2 wasn't transparent? Or were you able to push it to clipping before your ears gave out?Switching to Hifiman HE-400i to represent low but flat impedance headphone, the O2 was louder but you could hear its distortion easier.
That's what digital gain is for.There is also the issue of running out of gain if the source material is not recorded to max levels.
"It will never have enough power until I can spin the wheels at the end of the straightaway in high gear."When is an amplifier loud enough? When is gets as loud as you every want, plus a quarter turn of the dial. If you can't blow past your sweet spot, say "Nah, too loud" and dial back, then how will you ever know? How can you ever be happy?
At max volume, no. You can definitely hear it get distorted. That is why I prefer the JDS Labs Atom over it.Wait - the O2 wasn't transparent? Or were you able to push it to clipping before your ears gave out?
How do you handle that in a playlist of content???That's what digital gain is for.
Point taken.How do you handle that in a playlist of content???
The manufacturer sent it to me and they were wonderful in answering my questions early on. So I definitely owe them a review. Will do so as wired USB for now.Do you think it's worth the effort? You purchased this, right? You have to at least give it a listen.
Firmware v1.4.2 from Sept. 2018 added 24-bit USB for macOS sources. I asked Amir about the HD 650 in balanced mode, but he didn’t have a balanced cable for it.As long as everyone knows that the usb is 16-bit, and don't get mixed up about that, it might be OK to have a kind of provisional review. This device really should be measured balanced as well, there might be a great benefit with output power. The great disappointment with every bluetooth I have ever tried was weak output and way too much noise. I'm not sure if the usb input is representative of the level of noise while in wireless mode. They have a boatload of measurements on their site, one could measure on usb and estimate backwards.
The dac / amplification portion could be pretty much sorted out. That is a big portion of the puzzle.
I didn't know you listened to iems until recently. How come you never tried to give it a subjective listen? LDAC is built into newer Android, although I think it depends on the phone chipset being newer. That could be killer as well. Solves the transmitter portion of the puzzle.
Hi John - perhaps we can. Alas, I have a relatively small gear collection, decidedly mid-fi. Right now it’s a handful of FiiO IEMs, and a couple of open-back Senns (HD 545, HD 6XX). You can check it out here on head-fi:Hi Mike. Seems like you really like it. I've seen you mention it before, that's why it piqued my interest. I live locally, wonder if we might atg some point meet up and have a mini canfest. What other equipment do you own?
Looks like the Nx3s has a replaceable opamp. I'm quite tempted by this device to be honest. I would use it with my LG v30 allowing me to untether from my desk with full size cans.
