bkjernisted
- Joined
- Aug 21, 2022
- Messages
- 52
- Likes
- 5
In the sony xm4 headphone app you can slide a slider to the right or left to change the amount of base. How do you do this in the qudelix 5k equalizer?
Thanks
Thanks
No. The 5K only has analog outputs and the Mojo2 only has digital inputs. You can't connect them to each other.staticV3, can a mojo2 be Eq'd with a Qudelix 5k?
No. You cannot input analog audio into the 5K.Can I go from the analog out on the d50s with an rca to type c adapter into the Qudelix 5k to EQ the output of the d50s? My adapter is bi-directional.
Again: You cannot do RCA -> Qudelix. It doesn't work, no matter what kind of adapter you have.Can I go rca out on the d50s into rca in on the a50s and then rca out on the a50s into the Qudelix 5k using the bi-directional type c to rca adapter?
