Hipper
You can also buy flat cables that can go under carpet.
I see one on Amazon for $26, but it’s got no PVC jacket.I'm not seeing that, unless you're talking for a few feet. Looks like 14 gauge OFC is ~40c/ft vs ~15c/ft CCA. For 100 feet an equivalent one of the same brand but OFC is $40, vs $15 for the CCA.
This is the cheapest I can find...I see one on Amazon for $26, but it’s got no PVC jacket.
It's all a matter of distance. that 12" of thin wire inside your speaker won't change anything, but if you used another 20' of it, it would. The wire inside the voice coil is hair thin, but if you ran 20' of it to the amp and drove the speaker hard, it would turn red and melt!Having refurbed a couple of pairs of speaker and seeing the hookup wire inside, it makes me wonder about the need for my 12 ga. and 14 ga. speaker wire.
... but add a bucket load of new ones.distance & amps
BTW, if you put an amplifier close to each speaker, you solve some problems...
So glad you went with copper.Here is what I ended up buying based on the good information I got from you guys
Bare wires work well but are more subject to corrosion than banana plugs and therefore may need to be snipped and pushed back to clean copper every so often.
Is there a consensus here in the forum or possibly even a scientific study what is the best way to:
1. prevent corrosion at the copper cable ends of the speaker cables?
I wonder how much resistance a 1 or 2 mm coating has vs the bare wire?
I've had some early Monster cable turn completely green underneath the jacketing.Is there a consensus here in the forum or possibly even a scientific study what is the best way to:
2. if banana plugs are necessary or if it is sufficient to connect the cables directly?
the wire won't remain bare, but will corrode - that is what Tweek and the other polymeric conductive liquids prevent
Hydrochloric acid from the PVC is the villain in your little set piece.I've had some early Monster cable turn completely green underneath the jacketing.
I think it had some interaction with the jacketing material or some outgassing of it?
Thanks for the hint.
