- Joined
- Jan 15, 2020
- Messages
- 6,906
- Likes
- 16,968
The vertical directivity of the 8341 doesn't have that significant directivity mismatch as the 01 horizontally, also the vertical one will be even worse.Looks very similar to the normalized vertical off axis plots of the Genelec 8341(where the off axis rises above on axis at 3kHz).
I don't want to sound as party breaker but already the 0-30° plots horizontal show significant problems that I don't share the enthusiasm even less for that price, flat on axis isn't hard to achieve. The problem is they didn't use a waveguide although the small 4" mid helps and also that ring radiator tweeters beam alot on the last octave.
