GoosbumpsRbacch
Thinking of getting BACCH? My strongest advice is to JUST DO IT AND DO IT NOW!!
This is for those considering using BACCH dsp (BACCH) in their system but are unsure if it will work for them. I primarily wanted to give you an overview of my experience using BAACH4Mac without re-stating too much information already written. Many of my friends who have heard my system have either bought their own or are in the process of doing so. My motivation for writing this is to share my experience of BACCH with other serious Hifi enthusiasts using stereo systems and to encourage them to adopt this unique technology [1].
If you only want the “Executive summary” of this, please go straight to “Listening impressions” below.
My first experience with cross-talk cancellation came from using Carver C9 units (Holographic Generators) These used IC- OP amps (operational amplifiers) although good for their day (1970’s 80’s) they had less than ideal signal to noise ratio, a potential for line noise in some systems (impedance mis-match often requiring isolation transformers) and signal processing was done in the analogue domain not the digital. Their ability to accurately cancel cross-talk without introducing coloration was limited (even with extensive modifications to their circuits). BACCH (Band Assembled Crosstalk Cancellation Hierarchy) uses proprietary digital sound processing to achieve a true high-quality reference grade playback signal.
I had been following Edgar’s developments of BACCH (as well as other peoples’ approaches) to achieve realistic real-life sounding holography, but realised that Edgar had the deep technical understanding of psycho-acoustics and mathematical ability necessary to write the algorithms required to develop such a system. A system that was suitable and acceptable to the very high expectations of serious Hi fi enthusiasts – oka “people hopelessly addicted to sound reproduction” Although Edgar’s professional career involves Quantum Theory, Astrophysics and interstellar plasma propulsion systems etc. at heart he is an audiophile just like us.
The following is the most important point I’d like to make when considering BACCH.
Like most of us, I’ve spent significant money on everything hifi from power re-generators, fuses, cables, Schumann generators, dacs, isolators, Ethernet switches etc. We all chase the equipment that if correctly coupled and integrated into our systems may give us that extra 5% or 10% that we didn’t have before…be it at a huge financial cost. My friends have set their uber expensive gear up in my room because they tell me “It sounds better than anywhere else.” I believe that the main reason for this is because most people are not addressing the very things that erode the holographic sound-stage most of us are after… cross talk from speakers to our ears and reflections from untreated rooms.
This is what BACCH addresses (see heading below, Speaker choice and room). I’m not saying that all those other components don’t matter but what I am saying is that bang for buck, the BACCH system will give you what you always dreamed of (hence my username over a system without it….. no matter how much you spend on your exotic system!
What I have come to realise is that despite a friend owning a $140k (AUD) DAC, another $60k (at least) in cables and more $$…. for other gear, in my room, although sounding superb, for me, doesn’t compare favourably to having the BACCH4Mac doing its magic with the same mix of components. Even my “budget” system with the BACCH has way more holography, realism and emotional connection than without it. Knowing what I know now, I would recommend buying a BACCH system, not spend outrageous money on expensive cables 3 etc. walk away with bucket loads of $$ saved and have a system that is far superior in sound quality then one costing many times more.
BACCH4Mac
I took the plunge a couple of years ago and ordered the BACCH4Mac and I can categorically say this has been the most significant inclusion and upgrade to my system to date. If you can’t yet afford to buy a BACCH SP (Sound Purifier), do what I did, buy the Bacch4Mac, use your existing good quality speakers, cables etc. and DAC (however the B4Mac system has its own dac) and be the envy of your friends that just spent many times more on exotic components than what it cost for the B4Mac system with sensibly priced cables etc2
Even after I purchased my BACCH, friends urged me to sell my expensive server and use the Mac’s internal player (via Roon/Tidal) ….I have to say, I had major doubts about this however I confess they were right. After two years of not wanting to let my server go, I’m now selling it 3
The latest BACCH4Mac version 8.1 (Mid-June 2019) installed on the Mac Mini is a dream. It’s stable, reliable full of features and easy to use. The team at Theoretica have done a wonderful job of improving what was already a magnificent product!! They notify you of the free upgrades as soon as they are available and provide step by step instructions of how to install it correctly. The software only operates on Apple hardware and minimum requirements are specified on the Theoretica’s web site https://www.theoretica.us . Obviously the normal cautions apply regarding not plugging/unplugging cables etc. when the hardware is powered. If you choose to go down the BACCH4Mac software route, you need to be reasonably familiar with computers and be familiar with Apple OS.
If you just want to dip your feet in the water, are competent with computers and have the appropriate Apple device you might like to try the B4Mac Into-level software-only option on offer (for $980 USD). It provides “u-BACCH” filters created by a choice of either taped-measured distances (between speakers etc) or via (adjustable) audible tones (using the graphic user interface). Each method is very straight forward and allows you to set the system up quickly and have a listen.
Given the cost/benefit analysis discussed previously I highly recommend buying the complete B4Mac Audiophile, Plus or the Pro package like I did. They will set you up with a pre-configured Mac mini for a small additional cost (No amount of $$ or pleading with Apple Australia would convince them to build me a Mac Mini with an Ivy bridge processor, so I had no trouble deciding). Letting Theoretica take care of it all means you will likely have a far better experience knowing its set up correctly and get to enjoy the warranty that it comes with. The Audiophile and higher optioned versions come with in ear microphones to enable you to create a third type of BACCH filter (in addition to the u-BACCH filters). The Audiophile option and above also has head tracking ability and changes cross-talk filtering 4 on the fly to compensate for your head movements, thereby maintaining very strong holographic images, separation and layering etc.
The only issues I found with using the BACCH4Mac
If like me, your listening position is around 3m or more you may need longer usb cable/s to make the recorded filters via the RME digital audio interface that comes with the B4M (Ear mics plug into RME, then usb into Mac mini then usb to your dac, if you use your own). This will likely necessitate using an external phantom power supply for the RME (usb standard is only 0.5A @ 5v – not enough for long usb run). Also, if using your own external dac (as I do) you’ll find you will need to buy both a macOS compatible Blue tooth keyboard and mouse (to log in and use Roon etc. – I also use the Roon app on my android phone to control Roon.) Do not buy ones that require the little plug in dongles… straight blue tooth only (v3.0 or higher), thereby freeing up 2 usb slots!! Having an apple keyboard also avoids confusion when us windows people try to substitute the wrong key for the “command” key on the Apple keyboard…. This is not an issue if you are an Apple user!
BACCH SP
Finally, if you are not computer tech savvy or can’t be bothered tweaking software and/or don’t want to use a Mac Mini then the SP Series BACCH SP is for you. Completely self-contained one box turnkey solution (only the BACCH SP dio (digital in/out requires an external dac). SP stands for Sound Purifier. An accurate description of what they do! This range has the most advanced hardware to do all the processing and uses the very latest computing components……. My dream is to one day own a BACCH DIO and I’m saving hard for one!
Listening impressions (“Sensory perceptions with B4M” would be a better heading!)
When you listen to a stereo system with BACCH the sensation is almost overwhelming. The realism, the clarity (even compared to what you think is uber hi-fidelity) is extraordinary! When set up correctly you’ll have sounds jumping out of the walls and everywhere at you (at the same SPL). Your speakers really disappear. Forget ghost images…this stuff is really spooky in a good way The sounds seem to be “heard” by your brain directly. I mean it’s like your ears have been bypassed. Listening becomes even more addictive than before. It’s very exciting even after years of listening , I find myself still shaking my head in amazement. Am I really hearing this?
This is not a gimmick, it’s not a fly by night fad or some snake oil con. This IS the real thing; I believe it’s the future of digital stereo hi fi. I waited patiently for many years for this to be released and I can’t believe more people don’t know about it? It’s not creating anything that isn’t in the original recording, its purifying the sound quality by cancelling cross-talk contamination. By doing that, not only is it so much less fatiguing to listen to (ears to brain not confused by direction and magnitude of incoming sounds) but you get this magical 3-dimensional immersive sound field all around you ( something you can never achieve with surround sound and something you never completely achieve with the best hifi gear). When you go back to what you remember as your hi definition uber hi-resolution holographic hifi without BACCH (that you used to think was king) it sounds flatter, boring, and basically un-engaging compared to having BACCH in the system. There is no other way I could describe it.
Speaker choice and room treatment
My experience is that BACCH will work with most conventional speakers however speakers that have less off- axis are easier to implement. BACCH’s job is to cancel cross-talk. In addition, if the ratio of direct sound from driver to ears is shorter than reflected sounds, then that cancellation is more effective leading to better holography. I have used substantial room treatments (years before using BACCH) to limit the unwanted room reflections THAT DISTROY HOLLOGRAPHIC SOUND reproduction. So highly dispersive speakers in a highly reflective room is not an ideal situation if using BACCH or any speaker set up really. Notice how many more speaker manufacturers are using concave and not dome speakers these days? In order to limit in-room coupling/sound reflections from untreated rooms.
Don’t be discouraged to take up BACCH because you heard that you must have binaural recordings for it to work. Sure, not every recording produces perfect sounding BACCH 3d but I’ve not heard a track yet that sounds poorer with BACCH engaged. I listen to a wide range of music styles (more recently produced stuff than older these days) and the majority of them sound brilliant with BACCH. I urge anyone to make the effort and have a listen to BACCH and compare it with your existing system. I’ve done the exercise with a range of different components in my room and I much prefer BACCH 5 There are many other misconceptions about BACCH that I sometimes hear. Remember, this is not room correction software. It doesn’t modify signals to better suit your room or cancel bass nodes etc. None of that. I would say forget pre-formed notions of numbers/bit rates etc and let your ears be the judge!
Summary
If you are a serious hi-fier, I highly recommend BACCH. This is patented and tightly protected technology. They are continually updating and improving features and software etc. The team led by Edgar have put an incredible amount R&D into producing a range of BACCH packages to suit everyone and their support is exceptional. BACCH works! It’s the only one of its kind that does what it does! I’m lucky enough to experience this magic every time I “listen” to my stereo. Stop procrastinating and start enjoying your hi fi more than you ever have before! My only warning to you is there is no coming back. Once you hear it you WILL be addicted, no question about it, you just won’t want to go bacch to traditional stereo.
Whether you decide to use BACCH or not, I highly recommend you apply room treatment before spending a cent on anything else. A properly treated room will enable your speakers and other gear to reveal their full potential. Even if you don’t measure your rooms response (REW etc) simple treatments to reduce reflections such as thick carpet and wall drapes etc. will assist greatly.
Notes and other ramblings…
[1] Additional features available include BACCH for headphones and ability to create your own binaural recordings, Refer to https://www.theoretica.us for options. Please NB: the BACCH (SP) & BACCH dsp used in the BACCH4Mac are different. Both offer the ability to configure master clocking preference depending on the BACCH package you are using.
2 I’m not a cable denier quite the opposite, in fact the speaker cables (& other loom) made by a company starting with “S” in their S range are by FAR the best I have ever heard!.............. in a system without BACCH.
3 I upgraded my Mini with the Uptone Audio DC psu mod using their JS 2 regulated linear psu. Also be aware that the mini Theoretica link you up with has the Ivy pro i7 quad core processor with 16 Gig ram. This is the preferred model optimised for audio. Even Theorectica’s Intro level software option requires at lease Quad Core and at least 16 Gig to run the dsp software.
4 The word filter has a negative connotation as if something is being removed from the whole (sound quality). This is not the case in fact BACCH is a sound purifying system, a bi-product of its crosstalk cancellation process.
5 With the RME digital audio Interface connected the sample rate is 96kHz which is more than adequate for creating excellent crosstalk cancelling filters. After creating BACCH filters (using the in-ear mics) the RME can be disconnected and a usb cable run straight from the Mini to your dac. You just need to install and configure a programme called Soundflower. Once this is done you can increase the sample rate from 96 kHz to 192 kHz. Apparently it is not necessary, but I‘m about to try it…..
BACCH4Mac
BACCH SP
Summary
- If you don’t use the head tracking feature and are sitting outside the sweet spot, it just sounds like regular stereo.
- Incorporating BACCH with conventional speakers having wide dispersion and in untreated rooms still gives you holography but not nearly as strong as with directive speakers in treated rooms.
- I think Theorectica uses Apple OS for security reasons because they don’t want anyone hacking the system and stealing the software?
- My adoption and acceptance of BACCH in my system has made me stop and re-evaluate the design of a 3-way speaker I’ve been wanting to build for a long time. That’s how significant the BACCH experience has been for me.
