autoeq.app Is a Web Application for Equalizing Headphones the Easy Way
Wow - your response is so outstanding, I have no words to describe how good it is. Thank you ever so much.
In the interest of integrity, if there has been one thing I have learnt, everything is subject to change. And opinions, including mine, also change. Ears get tired after long days of listening and in the bright light of another day after a good nights rest, we hear things differently. Same - even after a few months, we hear certain things better.
It would be nice to live in a world, where we can change our minds, and say so, and that revision in our thinking is respected, and our honesty/integrity, is appreciated, but that is not always the case, sadly.
It was great to have come across AutoEQ, but I've changed my mind about it. Too many opportunities for inaccuracies. No certainty of how close your own copy of the headphone/IEM matches the specific copy you choose in AutoEQ's database, not sure what the algorithm is doing. Unfortunately with audio, any change is likely to be welcome to the ear, cos it's different and sounds refreshingly different. Question is - is it correct. With AutoEQ, which is a interesting idea, it fails in the fundamentals, similar to how any solution based on a database of measurements, will be flawed.
So this is not a criticism of AutoEQ itself, but that whole approach, and same applies to the Oratory based corrections. We also have the challenge of vetting the algorithms, of each of these methods. How correct are they? Pretty hard to tell. We are in uncertain territory.
@GaryH - sent you a far more detailed PM, explaining the assertions I have made here. And why although it also has similar issues, cos it is also based on a database of measurements, the immediacy of using a plugin like Morphit by Toneboosters, will deliver certain advantages, over AutoEQ or Oratory based corrections.
Thinking through the possible inaccuracies, I had to stop using AutoEQ, a few weeks ago. In another few years - hopefully measurement rigs of sufficient accuracy will become affordable, and we can do what we already do with speakers in a room, measure and correct the exact device we have in front of us.
If one thinks about this critically, no one in the speaker world would correct their speaker based on a pre-done measurement of another speaker. So why should we do this with headphones/IEMs? The approach of using a pre-measured result, is therefore, inherently flawed. Any use of such approaches, MUST have this caveat in mind.
I have had an interesting result with an alternative solution which you will find at PEQdB.com. Won't bother to discuss details here, cos its all easy to figure out on their web site. It also has some kind of database, at least of user preferences, and its algorithm is also not known to me. Nevetheless when trying this out I got the following interesting result
I pulled these into REW so I could see them side by side.
The green curve (see image below) is one of the measurements of my IEM - the ARTTI T10, from the squig.link database, measured by ToneDeafMonk, and not a measurement of my own copy of this IEM. The red curve is the correction generated by PEQdB.com
While the correction, generated by PEQdB.com seems to have also introduced my own personal listening preferences, into the correction, its somewhat uncanny to note, how there is a correlation between the correction, and an example of the measurement of another copy of my IEM.
At this time, I can say, I like the end result of the correction, better than the uncorrected result. Certain sibilances and harshness in the ARTTI T10, appear to have been reduced, and the end result is smoother. The bass has obviously been attenuated, I could hear this from listening, and it clearly shows in the correction graph.
I was already quite satisfied with the Non EQ'd result of the T10 with the eartips which I normally use on them, after tip rolling to discover what I thought was the most balanced. So the result of using PEQdB.com, was what I think at this time, is an improvement on an already excellent listening device, to make it sound that bit better.
Caveat. I did not have a similar positive experience attempting to correct another IEM, the CCA Polaris. But I also have not enjoyed listening to the CCA Polaris, without EQ, and any attempts by me to improve its sound by me creating EQ filters on my own from listening, had poor quality results, and I do not use this IEM for this reason, just not one I enjoy listening to. With or without EQ.
I think with PEQdB.com, the listening device itself, and how well it resolves audio, will have an impact on how one responds to the listening tests in PEQdB.com, and the effectiveness of the results. The ARRT T10 is a more resolving listening device than the CCA Polaris, to my ears, and most likely that is why I am having a more favourable result, with that IEM and the correction effort by PEQdB.com.
Big shout-out to OK1 for sharing his experiences with corrective EQ, IEMs, and other things.
Another revision. Full disclosure, and this is important cos things change.
I received a new eartip today. The Moondrop SPRING XL, thanks to recommendations from others on ASR.
With this eartip on the ARTTI T10, it so improved the clarity over my previous TRI Clarion eartips, that I no longer feel the need to do any EQ.
Furthermore applying the EQ which was generated using a pairing of the T10 and the TRI Clarion eartips, did not have a good result when applied to the XL's paired with the T10. It just sounded bad, bass shy, not a good sound. Tinny, not good at all.
What makes sense is for me to repeat the PEQdB.com correction effort, based on the XL paired to the T10. Ears are exhausted from a whole day of listening. Will D.V. occur some other day, when ears are rested.
Did you manage to get anywhere with FabFilter?
Unfortunately I haven't managed to get anywhere with anything related to AutoEq. I did update the measurements and results database, however, but even that was after a break of more than a year.
you can use this calculator to convert Q-factor from RBJ's implementation (used by me and also by AUtoEQ) to Fabfilter's implementation
I've played with the AutoEQ App website quite a bit and I've noticed that the results it gives vary a little bit each time you run a certain headphone through it. For example, select the HE1000 Stealth, then select the parametric settings for Equalizer APO. Now, go back and do the same thing again and the results will be slightly different. I doubt the differences are audible, but I find it interesting.
Also, I've never been able to determine if using a parametric file or a graphics file for Equalizer APO is better. The graphics settings for Equalizer APO uses 127 bands, and creates a more perfect fit to the target, but is that better?
Parametric EQ can always be tuned to be more accurate than a graphic EQ, but of course this requires some know-how.
AutoEQ is a great program, but it's a relatively simple algorithm, and the results can in most cases be improved upon, especially when it comes to filter limitations.
With a 127 band graphic EQ you can just brute-force the results, yes. So the question is then similar to "what is more accurate, vector graphics or pixel graphics?"
The answer is always "vector graphics", but if you increase the resolution of the pixel graphics to like 40 megapixels, then the difference might not be important anymore
