Is anyone interested in a iOS audio player with full Parametric EQ?
Do you want a local music player on iOS with full parametric EQ?
  • Yes!
    Votes: 23 79.3%
  • Yes, but I already use one:
    Votes: 1 3.4%
  • Nope
    Votes: 5 17.2%
Smaestro
TLDR: I made a rough, but working, audio player with parametric EQ for iOS devices. I wanted to make a system-wide EQ, to load for example AutoEQ profiles, but system-wide is impossible (without jailbreaking). However, I can continue and make a local music player app with full parametric (Freq, Gain, Q) EQ. There don't seem to be any, or many, on the App Store, only limited graphic EQ's. I want to see if this is something people want, as I don't have a need for it myself.
Hi all,
After 15+ years of using Android, I recently got an iPhone. To my surprise, there's no system-wide EQ option. So I started coding, and made a audio player with Parametric EQ. It's rough, ugly, but it works. Then I wanted to make it system-wide, but discovered that you can't on iOS without jailbreaking. This - of course - explains why there aren't any in the app store.
I was ready to can the project. I rarely use a standalone music player. BUT before I do, I want to ask, is there any demand for a local audio player with PEQ?
Please note: this would be for local files only. No streaming, doesn't work on spotify, apple or youtube, not on browser audio, not on phone calls. It would select one or more files from your phone, from a nice library or a basic "open file"-dialog, and then play them in the app.
Thanks for reading and voting in the poll. And if this already exists, please let me know.
Edit; I am aware of the list of iOS apps pinned in this forum. None of the apps in there seem to have an option for PEQ, only graphic EQ with fixed frequencies and no known Q factor. The Kaiser app comes close with some sort of "spline" line drawing EQ, but I think that's a "100 band" graphic EQ with a nicer interface. None are PEQ.
Neutron Music player. The Android/Windows versions have PEQ. I assume the iOS version does too.
Thanks!
Yes, it does have it listed under features. I've read over it.
I consider this thread closed.
Thanks, I am considering it.
What features would you minimal need to switch from Neutron to a new app, for the same cost as Neutron?
I’m thinking:
A library
Selecting which folders are part of your library
Sorting options in your library
Ability to make playlists (long term and ‘now playing’)
A player that can show artwork and play all the audio formats iOS supports.
And of course the unlimited band PEQ, with some ability to save and load, and m the ability to import AutoEQ style files.
Ease of handling playlists on the fly. Adding, removing, moving in the queue.
Replaygain support.
Thanks for your input. Those should be no problem.
In the Christmas break I’ll hopefully get to make some progress on it, that should give me insight in the total effort it’s going to be.
Since you're familiar with Android, I think GoneMad Music Player does many things right. Both in terms of interface customization and playlist management/creation.
That looks like a well-rounded app. I like how simple the interface is, and that the album art stays visible in the playlists. Good suggestion, really nice, thanks!
I wanted to chime in here. I only play 320kbps MP3 that I rip from FLAC files stored on my NAS. I currently copy them onto my iPhone and play them using the Apple Music app.
I’ve been searching for a way to add parametric eq but have found nothing. I am extremely interested in a simple audio player with parametric eq.
I’d love to be an alpha or beta tester.
Martin
I downloaded Neutron Music Player ($8.99) and it works well. I exported AutoEQ settings for my IEMs from Crinacle's Hangout and am trying them out. It's neat to be able to instantaneously toggle the EQ off and on to hear the differences. Cleaned up some of the muddiness on my 7Hz Timeless II by filling in the missing upper midrange / lower treble.
Martin
Thanks for the interest. I am currently overworked with projects, and soon I'll be travelling for several months.
Regretfully (because it does seem like a lot of fun), I won't be working on this.
Martin
My impression is that there are a number of apps that apply parametric EQ to music files added outside the Apple Music library to iOS and iPadOS devices, but that the only way to apply EQ to music added to or streamed from the Apple Music library itself on the devices is to use one of the generic EQ options (Rock, Jazz, Classical, Icrease Bass, etc.) available in the Music app settings.
In other words, no parametric EQ is possible inside the walled garden of the Music app (I think)….
I do not stream music. I have found Neutron Player to meet all my needs and wants. It's an extremely capable music player once you learn its quirks. Well worth $8.99.
Martin
This is exactly correct. The required audio libraries that allow for parametric EQ don't have access to any audio streams (both calls and music apps).
Apple says it's to prevent apps from unauthorized eavesdropping and recording of your voice calls. For parametric EQ to work on streams, iOS must change how it handles music audio streams.
Surely it should be possible to have two different paths for audio. A protected one for voice calls from Phone, Signal, WhatsApp, etc. and a regular one that could be accessed by DSP apps.
Possible for Apple to implement, I mean.
That’s a pity.
Have you consider to code plugin for parametric EQ in existing player? I’m thinking VLC player for iOS. I hope it can be done. Otherwise, please ignore my lack of technical expertise.
Take a look at an iOS app called Denon Audio it has an equalizer feature, plays radio, and works with Carplay. I might have loaded the Library through iTunes just to get them on the phone (been so long I forget) but it works well.
I built an iOS app (Nuotit) that has a 9-band PEQ with dynamic processing (compressor, expander, limiters etc.). It plays local audio files, and RSS-feeds (podcasts). Audio profiles are shareable (import/export) and can be assigned to playlists, podcasts or even files.
Happy to elaborate more.
