Audeze LCD MX4 measurements
I believe our brain already compensates for our Pinna and ear canal through daily calibration with real sounds and knows when sounds are coming from what angle and how to 'EQ' those sounds internally.
This is accurate in that we "filter out" our HRTF from our perception of timbre, but as you note here, the perceived source is a significant factor. The was a core component of Theile's classic case against free field compensation targets. However...
IME there is more correllation using a flat plate and feel that any changes made to the incoming sound waves ('universal Pinna' and sometimes fake ear canals) cause irreparable 'damage' as the exact compensation curve is obtained using very different methods that look nothing like when a driver is just a few cm from the ears.
I don't believe in F-ing up a measurement of a driver and try to repair it later for correlation.
Usually I compare this with measuring FR of a DAC through a filter that can have 20dB differences and where the filter changes somewhat every time another DAC is connected and then apply a digital and fixed filter that compensates somewhat.
Here you have the situation precisely reversed - using a flat plate coupler will produce highly variable FR deviations between headphones relative to what we would measure with the headphones on a human's head, with attendant disparities in FR vs. subjective timbre. To illustrate this point further, I have done quite a lot of measurements today on a HATS vs. a flat plate
As this amounts to unreadable soup, I have, as before, subtracted the on-HATS measurement from the earless flat plate:
And then taking the minimum and maximum values to show the worst-case spread by frequency:
Distinct from the last time I did this, I included more different types of headphones (smaller over-ear, on-ear, more closed-backed models, more models with different pad designs), in an attempt to be more representative of the range of different headphones a measurement system could encounter. As you can see, the variation by headphone is quite massive, with a worst-case error over +/-106dB, even discounting variation in the coupling-dependent band. Given that such deviations in frequency response would be massively audible, and that frequency response measurements on industry-standard system are strongly correlated with subjective perceptions, I cannot see a conclusion here which would support the use of an earless flat plate system for characterizing the frequency response of headphones, with the exception of an assembly line QC fixture or other case where only a single model's unit-to-unit variation needed to be monitored.
Edit: I neglected to note that all frequency response measurements here are an average of five placements of the headphone at slightly varied positions, to control for positional variation, as in my past posts on this subject.
Edit 2: Looking through my excel sheet, I realized that I made two key errors with the difference plot: 1, I included one column which I shouldn't have in the "min" values, which resulted in an excessively "negative ear resonance" shape on the plot. However, after correcting it, I realized that the "max" values were actually drawn from the "average" column - it would seem I made one mistake in sympathy and one in antipathy toward flat plate couplers without ears :p The current plot is now accurate and makes much the same point with regard to the accuracy of flat plate measurements.
Yes, I agree that the raw measurements you compare differ up to 20dB.
That's what I meant with you want to measure the sound coming from a driver (20mm away from your head) and you route these soundwaves through multiple resonating filters (ear canal and Pinna) which, in order to get a good relation to perceived sound, would have to be undone.
The reason it has to be undone is that we hear using Pinna and ear canal so the brain already compensates for this based on daily 'calibration'.
Daily calibration exists as when we get older our hearing gets worse yet we don't experience it that way.
So you have a sound source, run it through a Pinna which reacts differently to each headphone (see Rtings research) and then through an ear canal.
Both of these are 'standards' which differ per manufacturer it seems.
Have a look at Pinna from people around you. They all differ. Some don't look like the one on HATS. Yet, all of these folks perceive a piano as a piano and can say if it doesn't sound like one. The sound arriving at the ear drum differs. The brain 'calibrates'.
So sound source -> Pinna resonance filter (headphone dependant) -> ear canal resonance/filter -> microphone.
One would have to UNDO these resonances to (which is a combined set of resonances of different Q and frequencies in order to arrive back at the point of what the driver emits. In the end... that's what we hear.
When that compensation is an average one based on free field or whatever field with speakers as point source(s) a few meter away then you can be absolutely assured that the measurement is completely and irreparably flawed. Simply because the compensation used does NOT belong to that headphone and thus the measurement result differs.
That's why different HATS also differ in raw response and need their own compensation.
That compensation is NEVER made with a headphone.
So... even when compensated the result may differ a LOT from what came of the driver. And as a result we perceive the sound differently from what is shown by the output of a compensated plot from a HATS.
Let me invite you to take a look at the the K712 and HD650 at Rtings.
I own both and according to the (compensated) plots these headphones should have similar tonal balance right ? There are some 5dB differences locally but the average tonal balance would be the similar.
Now have a look at my measurements of K7XX (which IMHO = K712 with a foam disc added so on my websit,e that has irreparably damaged and flawed to the core worthless measurements on it, compare the HD650 with the K7XX.
These differ substantially (which is the flaw you feel is the case as they should measure like the Rtings comparison).
These irreparably flawed measurements of mine indicate the K7XX is noticeably less 'forward' and is 'warmer' sounding and has less clarity. Also the more ragged treble response of the K7XX indicates the 'coarser' treble compared to the HD650.
Now the proof is in the pudding here. Compare these headphones directly (sort of level matched in the lower mids) and LISTEN to these headphones. I own both so is easy to do. I can assure you these headphones sound totally different tonally and has a very high correspondence with my irreparably damaged measurements and not like the ones from Rtings.
Furthermore you can do the following experiment (well everyone can, no measurement rig needed) and invite folks to test themselves.
Pick 2 headphones that are measured using a HATS and by me (please don't do this with plots from other flat plates, they don't measure the same as mine) now apply EQ based on the different plots.
So the K712 (K7xx with foam removed) and the HD650 for instance and EQ them to the plots made on a HATS and compare the perceived tonal balance/sound between them. Do the same but with both headphones EQ'ed acc to my measurements.
Listen and compare the 2 headphones and then conclude which headphones sound more closely the same.
And... which one sounds the most 'natural' on well recorded music.
Then one can truly say which measurement method is closest to 'reality' and which is the most irreparably damaged.
Do these experiments.. your ears can be trusted with such test... and then you know
Don't take my word on it !!! nor someone else's.
That's all I have to say about it. Graphs should have a relevance to the perceived sonic differences
We do not - and should not - measure the driver of a headphone (well, except when we do, but not for purposes of assessing consumer headphones). The headphone on a head is an acoustic system which begins at electroacoustic transduction and ends at our eardrum, and it is this system's net response which is significant to our perception of sound.
I must note that there is no single fixed function for our ears - our brains will filter out HRTF effects from timbre, but as Theile demonstrated, only as appropriate to the perceived sound source. If you lack an AES subscription to see the previous link, here is a separate hosting of Theile's seminal paper. Theile and Olive's work appears to imply that diffuse field HRTF inverse filtering gets closest (note that the "basis" of the Harman response, an in-room measurement in a fairly diffusive room, is quite close to a smoothed DF.
I actually would argue that different pinnae do interact differently with different headphones, following Völk's paper here, but I'm somewhat confused that you've taken that away from anything on RTings.
Presuming you are making reference to RTings' PRTF test, wherein a pinna-less and pinna-equipped version of their HMSII.3's ear plate are compared, you can surely see how the data falls into alignment with what I am saying: when we compare the state of being without a pinna to having one, headphones vary in inconsistent ways. However, a pinna in the earpad is the normal state of operation for headphones, so I would argue that it makes far more sense to regard this as reflecting the variability of impacts of removing that key part of the acoustic system. Supporting that would be the fact that putting any pinna on the measurement system yields convergence of results with my HATS, even non-IEC ones like the EARS' - while there are still variations, they are smaller than what we observe on the earless flat plate.
The compensation should not be a headphone unless the goal is to show the disparity in response between that headphone and some other source for the HATS in question. I use diffuse field as my target because, following from Theile's research, I feel that the data supports that a diffuse field flat headphone will be perceived as accurate (perhaps slightly modified with broad shelf filters for preference purposes) - people who prefer to compensate to Sean Olive's target likely feel the same, or prefer to target to the result which is most commonly preferred.
While HATS do vary, the variations between them are far lower than the variation I show in the comparison of flat plate and HATS data (section 5.2 has overlays of all three major HATS models). There is definitely still room for interpersonal variation in interactions with headphones, and indeed I think this is a potential vector for the variations in frequency response perception that exist vs. some of the data we have, but the fact that work like Olive's can produce strong predictions of preference based on measurements of headphones on systems with pinnae strongly implies that whatever differences do exist are not massive.
I will also point to the various research of Dorte Hammershøi and Henrik Møller on HRTF and headphones, including most pertinently this particular paper. While sadly it does not compare individual diffuse field HRTF to headphone FR on head - which would answer many questions - it nonetheless shows relative response consistency, and notably the range of variation is similar to their other work on HRTF.
I was honestly prepared to suggest here that your ears were lead by your gear - a problem which has befallen me many times before before when I leaned too hard upon poorly-made measurements - but upon comparing the plots, I am uncertain of your issue with RTings' measurements (other than, of course, their rather strange and ill-grounded house curve). RTings measurements reflect a drop on the center of the midrange for the K712 vs. the HD650, the iconic rise around 2khz which most of those AKGs feature, and a generally uneven response characteristic in the treble (which I would put at least some faith in as far as its internal details, as RTings made the commendable-albeit-weird choice to keep the shape of the DF HRTF past around 1.8khz, while merging it with a rise into ear resonance which was apparently made from whole cloth), which also seems to cohere with Innerfidelity's measurements of the K7XX and HD650.
I suspect that RTings' tendency to align headphones somewhat arbitrarily (has the alignment their tool uses ever been explained anywhere? I haven't seen it) gives you a misleading perception of how similarly they measure there - the two headphones' response looks different enough to be substantially subjectively different to me, and, indeed, in alignment with my memory of how the two compare for the most part. We are very sensitive to variations in FR in the midrange in particular, and the two diverge substantially there.
Different flat plates do have some differences - flush vs. protruding vs. inset microphone mounting being a major impact - but my flat plate which I used for this measurement is fairly analogous to your own, to my understanding: a flush-set microphone in a plate covered in closed-cell foam. Regardless, no difference of earless flat plate construction will resolve the problems we see here - we observe the same in IEC60318-1 couplers.
If we are making our final statements here, I will offer a short summary for mine:
  • Disparities in response exist between different systems for measuring headphones which vary based on the headphones measured - that is, cannot be consistently compensated.
  • The systems without pinna display the greatest disparities from the systems which most closely resemble the acoustics of a living human's head.
  • Measurements conducted on the systems which most closely resemble the acoustics of a living human's head can predict subjective perception with at least fairly good accuracy.
I feel that the implications for what measurement systems are suitable follow fairly clearly from here.
As an aside, it is odd to me that we still have these sorts of dialogues in 2019. In 1984, Floyd Toole already wrote of the measurement of headphones on anthropomorphic measurement fixtures as a necessity, including comparisons to in-ear measurements of humans. A recurring theme of technical discussions that I've had in the world of headphones lately has been that I find their exact subjects referenced in literature from before my birth afterwards - it seems that in the world of headphones, at least, there is nothing new under the sun.
