At what level is noise heard in your system?
RayDunzl
Central Scrutinizer
Riverview FL
Normal (even loud) listening creates a current draw nowhere near the limit of the mains circuit.
And yes, average is 15 to 20dB below peak.
TV is running right now: peak 17.2dB above average
Wombat
Australia
If you can hear system noise from your listening position at idle then you need to attend to system connections, house wiring or, heaven forbid, your choice of componentry.
If you can hear it at listening levels you need another interest.
(or learn real stuff vs internet chatter).
RayDunzl
Central Scrutinizer
Riverview FL
etc6849
Columbia, SC
etc6849
Columbia, SC
No cal certificate, but I paid about 1/5 of new price so I'm happy. I tested it with a cheap SPL meter I have and it appears to be accurate. Should be really nice for calibrating level in REW since my mic came with a cal adapter.
Did it come with a current Calibration Certificate?
etc6849
Columbia, SC
@RayDunzl
Thanks Ray! I learned from and liked the settings you used, so I copied them :) I'm using a Benchmark ADC1, Benchmark MPA1, and a Earthworks M30 (all bought from eBay).
A complete file with these saved measurements: amps off lights off, amps off with lights on, amps on, and the calibration source set to 114dB is found below:
https://drive.google.com/open?id=1sB-dLejnQvsE9mvUBLGA0_A5mZRzm143
Amps off, lights off (I'm outside the room too):
Calibration source I got from eBay set to 114dB:
Reactions: trl
RayDunzl
Central Scrutinizer
Riverview FL
I didn't expect to see such a high level of harmonic distortion, but, I have no experience with a calibrator, nor a mic at those levels.
Comparing the UMIK-1 and REW readings with two other meters made me think "close enough".
114+70+83+50 = 114.3dB, so I guess it doesn't matter.
etc6849
Columbia, SC
Thanks! It seems super handy for what I paid, but I'm glad I didn't pay $220+tax for it.
As you point out, it is so close it doesn't matter. It seems it is likely within the specified accuracy of +/-.5dB. I would think the 94dB reading would be cleaner, but I already put everything up or I'd check, doh!
http://www.amprobe.com/amprobe/usen/environmental-testers/sound/amp-sm-cal1.htm?pid=73340
Electrical (sound) standard: ANSI S1.40-1984 and IEC942 1988 Class2.
Output sound level: 94dB and 114dB re 20 uPa under reference.
Accuracy: ± 0.5 dB.
Output frequency: 1 kHz ± 4 %
trl
King of Mods
Iasi, RO
RayDunzl
Central Scrutinizer
Riverview FL
I wonder if the +40dB @20Hz is really there or it's measurement issue.
I can't say if the reported LF levels are correct, but the reported SPL increases and decreases with human activity, as I interpret the 2am and 3pm readings above.
etc6849
Columbia, SC
I would think it has to be the room as the mic I am using has a ~22dB self noise (latest Earthworks M30 has an even lower self noise).
I don't think it is the equipment, but... This weekend I will test an analog loop-back via a Benchmark ADC1 and Benchmark DAC3 DX to be sure.
I wonder if the +40dB @20Hz is really there or it's measurement issue. However, it's really quiet in there. :)
Blumlein 88
Blumlein 88
Trains can really muck up low frequency levels from miles away.
RayDunzl
Central Scrutinizer
Riverview FL
... and helicopters.
etc6849
Columbia, SC
For fun, to check my volume control (RME TotalMix using the Hammerfall DSP ASIO driver), I was able to get a digital AES loop-back by connecting the AES inputs and outputs for CH 8 of my RME card. I then used REW's generator to output a 1kHZ sine at 0dBFS.
I changed the volume in TotalMix as shown below (-62dBFS, -50dBFS and -30dBFS). Using a 512k FFT length (to lower noise floor of measurement) and RME's ASIO driver (aka Hammerfall DSP).
Pretty neat that I now know conclusively that the RME's volume control is absolutely never going to be the bottleneck in my setup. RME's implementation is discussed here: https://www.rme-audio.de/english/techinfo/hdsp_tmhard.htm
I have to say, I am really liking REW's RTA feature. A special thanks to Ray's for getting me started with the right settings.
RayDunzl
Central Scrutinizer
Riverview FL
Blumlein 88
Blumlein 88
Short thread: https://www.avsforum.com/forum/91-a...measuring-ambient-room-noise-below-20dba.html
"I used a Lewitt LCT-550, Motu 624 and a CM-140. The 550 is rated for 0db electrical noise and 3dbA acoustic noise."
That is interesting. I've got a microphone with a 6 db self noise rating (Shure KSM44a). I'll have to try it vs the Umik. I also have an earlier version of the Lewitt 540 which was rated at 8 db self noise. And the 6 db mic is multi-pattern. 6 db is for omni, but it is 4 db for cardioid (which the 550 is as well).
MrGoodbits
Knoxville, Tennessee
I followed instructions and could hear (just barely) the 70dB file. That makes me strangely happy. Only you guys would understand why.
wadec22
@Blumlein 88 thanks! this was fun to try!
I think my setup is pretty typical. I can hear the 70db at normal listening levels (barely). Obviously cranking my desktop setup I can faintly hear the 90db.
This does change perspective looking at the SINAD tables. Basically take anything 90db+, then find the feature set & price combo to best suit your needs and good to go.
Probably not to different from cars. Most on the road can certainly go fast enough for 99% of use cases. All about price & features. :)
Still very fun to search for impeccable engineering.
