I'm talking about speakers and dsp not amps.
Fine
Peoples' memory for sound and what it sounded like or not is about maybe less than a second. 5 seconds is too much never mind 5 minutes, 5 days 5 months or 5 years.It may not seem like big differences in the beginning. But day after to day for over a year the differences can be seem big enough to set a sonic preference.
Perhaps one or both need servicing?I can tell a difference between my Yamahas and Luxman.
But have you done so in a level-controlled blind test? I very much doubt it. You are swimming against what we know about sound perception and measurement.I can tell a difference between my Yamahas and Luxman.
I can even tell a difference between the Yamaha AS-3200 and Yamaha rn-2000a. I thought the AS-3200 sounded bland by itself. When I added the rn-2000a as a preamp instead, it sounds more colored which I liked.
It may not seem like big differences in the beginning. But day after to day for over a year the differences can be seem big enough to set a sonic preference. Is this going to really upset some people that I can tell a difference?
And what about reviewers like Steve Hoffman, Andrew Robinson, etc when they review amps and describe the sound characteristics? The don't say all amps sounds indistinguishable so we won't cover that.
Well then go ahead. Everyone seems to make that claim.If it was a blind test I could absolutely tell the differences. They are significant enough to where it would not be hard.
And again, what about reviewers like Steve Hoffman, Andrew Robinson, etc when they review amps and describe the sound characteristics? They don't say all amps sounds indistinguishable or it sounds like 'other amps in the same class'.
Other than a big difference in total power output they have good enough specs to be indistinguishable from each other as long as not at clipping. The more powerful one has a advantage because the level of power on the lower powered one is pretty low.you're right with the two amplifiers you might hear different sounds, but I would say more: they allow the speakers to sound different.
No, it is not. It is in large majority the speakers that contribute to this and providing he chooses from 4 Ohm speaker impedance rated amps he should be good to go and then he just needs to decide on what amp he wants to get.The timbre or musical signature is the result of how an amplifier handles the speakers.
Yes, and at this range of power output it is best to get the more powerful amp even if it costs way less and so the Yamaha looks good.they amplify a different frequency range, manage transients and peaks differently and above all they suffer the characteristics of the speakers in a different way.
rocky 4 THX./TAP
It's very important to realise that people like that don't know what they are doing.If it was a blind test I could absolutely tell the differences. They are significant enough to where it would not be hard.
What about them? They don't test amps properly, treating them as some kind of mystical device rather than an electrical amplification device and providing nothing of note.And again, what about reviewers like Steve Hoffman, Andrew Robinson, etc when they review amps and describe the sound characteristics?
It's an acquired taste...like when one is small, one doesn't like asparagus but over the years and into adulthood, one likes asparagus. No biggieFor couple of years now I have had a Yamaha 2000a that I use a preamp to the Yamaha AS-3200. I always loved the sound. A year later I bought a Luxman 595 Class A amp. I didn't like the sound of the Luxman.... I thought it sounded stuffy and did not have the openness of the Yamaha. This is over the course of about a year. But recently, I have found myself listening to the Luxman more (no preamp). I like the punch and meat it has... and although it does not have the openness of the Yamaha, it has superb holographic sound in it's own manner. When I switch back to the Yamaha, I still appreciate it's open sound (which is much better than Luxman) but I find it a bit to bright for me on some music.
It doesn't make sense to me how after all this time I can like the Yamaha so much more than the Luxman, and then begin to prefer the Luxman more and also bothered by the Yamaha's brightness. I guess my tastes are changing over time? Is that normal in this hobby? If so, it seems it could be very expensive if my tastes change like this.
Note: Everything with Focal Sopra N1 speakers, always. And in the same listening spot, always.
Note: This isn't a diss on Yamaha... I think the Yamaha is actually better than the Luxman in it's design, build quality, meters, and value.... just preferring sound signatures
Timbre is a result of the harmonic frequency spectrum of the sound. If operating within spec, most amps will send the exact. same signal to the speaker (ie they would null to inaudible if one was phase-reversed). The loudspeaker will introduce an order of magnitude more harmonic and other distortion than any decent amp (like the two in question). Only an intentionally distorting design (like some tube amps) will affect the timbre by itself.The timbre or musical signature is the result of how an amplifier handles the speakers.
