audioBliss
Assuming all goes well, I plan to review Dirac in this AVR.
Hold down the Menu button on the unit for more than 4 seconds and an extended menu will appear. Check what version you are on. It should be 7.14 - if it is not it is no use to test Dirac because it is broken on previous firmwares. Latest firmware can be found here https://www.arcam.co.uk/product,fmj,av-receivers,avr390.htm at the bottom.
As for Dirac do not download from Arcams website since this version is years old.. Download here
https://live.dirac.com/download/
When setting up Dirac Arcam does not ship with any target curves or anything so only Dirac default is used. This is only a baseline to start with. You can find better curves here
https://mehlau.net/audio/dirac-live-2/
Config
https://mehlau.net/audio/dirac-live-2-mic-speaker-levels/
I would also like to add that these units where announced back in 2015(https://www.facebook.com/AVSforum.n...live-at-cedia-expo-2015-arc/1023783854351750/) and people started using them 2016 so they have been in the market for a while. They were the first to market with Dirac in the cheaper segment, years before the competition. That was the draw to these receivers. Before this it was basically the Datasat RS20i for $20 000 that had Dirac.
Edit: This receiver needs care when setup..for every input
Use the setting "As Speaker Types" and make sure you have the speaker types set correctly(large if no sub in system, small otherwise).
Follow the instruction for firmware update very carefully (if upgrade needed) or all sorts of stuff messes up in the AVR (I.e. make sure to reset to factory defaults after upgrade)
