Practical Amplifier Slew Rates
It’s been established that, above some frequency point, the slew rate of an amplifier will play a major role in distorting the signal.
The equation to find the minimum slew rate of an amplifier is as follows:
Slew Rate = 2 π • Frequency(max) • Voltage(peak)
So, what would be a bare minimum amplifier slew rate?
Remember that the slew rate specification, though it may seem like it has to do with dynamics, actually has more to do with high-frequency distortion.
From <
https://mynewmicrophone.com/what-is-amplifier-slew-rate-does-it-affect-performance/>
Measuring Slew Rate or Rise Time
Slew rate is specified as a change in amplitude with respect to time (dV/dt), typically shown as V/µs. Slew rate is considered a large-signal performance measurement, as opposed to rise time which is a small-signal performance measurement.
From <
https://www.ap.com/blog/measuring-slew-rate-or-rise-time/>
Dynamic Power
The dynamic power of an amplifier is measured by repeatedly feeding a 1000 Hz signal for 20 milliseconds (or another short amount of time) followed by 480 milliseconds (or another longer amount of time) of no signal.
The amplifier volume control is turned up until the amp reaches the clipping point. At that point, the amp has reached its instantaneous peak or dynamic power output.
This rating, again, is listed t boast higher power rating numbers in order to make the amplifier look more powerful than it is.
From <
https://mynewmicrophone.com/complete-guide-to-power-amplifier-specifications-data/#Dynamic-Power>
