I guess it is too late to make this a poll, or there may already be one somewhere here!
Results would be interesting to see.
Out of curiosity, of these other systems you've heard, how many have been two channel systems and how many have been home theater/multichannel systems?I'm just saying that to this point, I still haven't heard it done to my satisfaction.
Haha yes some songs have enough bass to give you a headache.Very sorry. Got distracted by kids and dinner and messed up my post. ryanosaur pretty much said what I’m hearing and what I do. I will say there are very bass heavy recordings I will dial back the sub. Most times I think I’m right when I do this but I have to wonder if the intent wasn’t to have a nice bass thump. I’ve been listening to a ton of late 70s funk and bass guitar is driving the song.
Yes you are right. I ran a sweep which was okay. But then I also played from the Alan Parsons sound check 2 album the 1/3 octave tones at 20, 25, 31.5, 40, 63, 80, 100, 125Hz.To be clear: it's not 80 Hz that you're hearing. It's the harmonics at 160 and 240 Hz, content from bass managed channels between 80 and 240 Hz, and/or any vibrations giving away the location of the sub.
I tried to read it but it doesn’t play well with iPhone. Any points you got from the article?
Also some further interesting references within this paper.
JSmith
I'd suspect that the vast majority of people that feel the need to turn down or adjust their sub for some songs vs others don't have their sub(s) EQ'd and room corrected. When you have a room mode with a big peak at a specific bass frequency, and a certain song keeps hitting that same frequency with a lot of energy, you get droning and booming and it sounds terrible and it's fatiguing. This is why I say subs generally suck without EQ.Haha yes some songs have enough bass to give you a headache.
Yes absolutely. After correcting my bass I never felt like turning down the bass. Maybe turning down the volume but that’s different.I'd suspect that the vast majority of people that feel the need to turn down or adjust their sub for some songs vs others don't have their sub(s) EQ'd and room corrected. When you have a room mode with a big peak at a specific bass frequency, and a certain song keeps hitting that same frequency with a lot of energy, you get droning and booming and it sounds terrible and it's fatiguing. This is why I say subs generally suck without EQ.
Below is the room response for my home office system, both with and without EQ. With EQ it's nice and flat all the way to 20 Hz (aside from the suckout at 50 Hz that can only be fixed with a 3rd sub). I have never once had to adjust the subs because some song had too much bass, because the subs are dialed in with a nice flat response. Without EQ, I'd hate my subs with every song that had a lot of repeated bass energy around 57 Hz or 74 Hz.
I do too. Sounds great with music. However if I run those tones I hear the resonances. Not all rooms can handle it.Huh. If you have a little knowledge and the right tools it doesn't have to be hard. I just put one sub at the front, one sub in the back, run room correction, and I have smooth bass that sounds great at any volume level. Far better than speakers alone, and I have good speakers, too. I would invite everyone in the thread over to hear my system if it were possible - just so you could hear how good it is. I'm not one to brag but I say with a lot of confidence that no one would be left wanting.
Thankfully it’s clean from 20-63Hz. There is some fireplace resonance but far less than before I stuffed it and applied monster bass panels in front of it.
80Hz causes a resonance from the left subwoofer. 125Hz causes one from the right subwoofer. Even 63Hz is not fully clean.
80Hz causes a slight resonance from the left.
100Hz causes a resonance which is centered.
Now to get here I have monster bass traps on the entire front wall from floor to 24”. Also 2 tri traps on the front wall edges.
I have 244 traps on the entire front wall from 24” to 66”.
All this work and my bass is still resonating.
No wonder people just give up on it. I did everything right. 2 subs. GLM correction. Intense acoustic panel treatments and still it’s resonant. It’s a lot better than before but still not close to prefect.
The only silver lining is that it seems to need some time to build up the resonance. So a sweep is actually quite clean. Playing the tones reveals the deficiencies.
It turns out 63-125Hz is very difficult to tame.
Yes I have 20 bands pEq on each monitor and sub. The subs are corrected to flat in the listening position. But resonance could be anything. It sounds like it’s coming from the drive unit on the left but that can’t be unless the sub is defective which I doubt as it’s brand new. On the right it’s coming from somewhere. I have to investigate further.So do you have EQ?
Agreed. It’s there. Maybe there. Probably not on music.I've heard them, too. It's very annoying in the mid and upper bass tones. But I'm not sure I can hear them with music which doesn't use such output on constant tones.
You are forgetting intermodulation between tones which produces difference frequencies.LightHeartedMode: well, The Undertones were a favourite of John Peel
But in music, no. In it's simplest sense, a musical sound is made up of a fundamental, plus it's harmonics. So, if you have a tone at 44Hz, it's either the fundamental (nothing lower) or it's an harmonic of, say 22Hz.
https://history_philosophy.en-academic.com/52/Greek_arithmetic%2C_geometry_and_harmonics%3A_Thales_to_Plato
I think I said "in it's simplest sense", so I was referring to resonance on a string, hence the reference to Plato and the Greeks in c 500BC.You are forgetting intermodulation between tones which produces difference frequencies.
I see so even if there are no fundamentals under a certain frequency there can intermodulation under the fundamental?You are forgetting intermodulation between tones which produces difference frequencies.
