- Joined
- Aug 14, 2018
- Messages
- 2,778
- Likes
- 8,164
I've unexpectedly got the opportunity to have a pair of good-condition Infinity Kappa 9s at no cost (except that of moving them to my location).
They were being run with an Adcom GFA-5800, but I have exactly zero desire to replace my current Purifi amp with a 60-pound space heater (and one that will almost certainly emit mechanical hum in my location because of DC on the AC line). I had a GFA-5400 for years and I liked it but was glad to replace it with the lower-noise Purifi and don't want to go back.
I'm impressed by the Kappa's soundstage height and the sheer ability of those 4x 12" woofers to move air. But I've never been into gigantic, room-dominating speakers - and more importantly, I'm leery of their bananas impedance curve.
I don't listen at terribly loud volume at home - typically 75-85dB. But with the Purifi I'd be running the Kappas at about 60% of the power of the Adcom GFA-5800. The Purifi is able to pump out about 90% of the Adcom's power at 1%THD, but at 1% THD the Purifi is already clipping (unlike the Adcom, which is spec'd to run at 1.8% THD), so that's not really sustainable. And I haven't really paid much attention to what a Purifi-based amp might do when presented with the very low-impedance load the Kappa 9 presents at certain frequencies.
So... should I:
1. Get a 2nd, identical Purifi amp and bi-amp the Kappas?
OR
2. Try replacing the Purifi with a Hypex NCx amp that has more power?
OR
3. Return to my plan before this opportunity arose, which was to get a pair of Genelec 8351s? I could sell the Kappas and my Purifi amp and put that money towards the Genelecs.
Comparing the cost, I'd estimate that transporting the Kappas and buying a 2nd Purifi amp could run me roughly $2k. On the other hand, if I sold the Kappas and my Purifi amp and put those funds towards the Genelecs, my net cost for the Genelecs would be something in the neighborhood of $4k-$4500. That's a significant difference, but not a deal-breaker difference when considering what I plan to be my forever setup.
I'm not a big bass-head and I don't listen at very loud volume as noted above. I have a decent-sized listening space (about 270 sq ft) and listen about 2.5M from the speakers.
@Doodski , I know you have a lot of experience with the Kappas - do you have a thought about this? Anyone else?
Thanks!
So... should I:
OR
OR
Thanks!
