dasdoing
yes
To clarify, when I say room correction, I mean so I can perform the max SPL tests indoors. Using Klippel’s ISC module, one just needs a proper “reference” (outdoor, NFS, anechoic) and then other measurements can be taken indoors. This is useful for various reasons. In this case it keeps me out of the summer heat and isn’t as annoying to my neighbors.
https://www.klippel.de/products/rd-system/modules/isc-in-situ-compensation.html
Elac showed up and testing is now done! (Unless I decide to test the Klipsch a 5th time to try to see if I can get a 20Hz reading that isn’t distorted above my noise threshold; no other issues with the other woofers).
A few things I have learned today while testing some of these subwoofers:
1a) There's a whole lot of amplifier limitation (built in limiters) in this price range.
1b) If anyone ever decides to do their own testing, there is no reason to increase the voltage input past 2v if you run the gain wide open. All the limitations seem to be kicking in well before that. I assume the amps are all built with the expectation of relatively low voltage input from the AVR pre-out.
2) Room correction via Klippel's ISC does indeed work as well as I had hoped. I doubted some of the results so I packed everything up and brought it all outside. Three tests later and the results are the same as they were indoors, using the room correction. Oh, well.
3) I like the Elac. Not saying it is the best. But I like it.
4) Depending on your needs, there are different “winners”. Trade-offs. I have plans to approach the data with various viewpoints. IMHO, a single CEA-2010 curve isn’t a full representation of the best option for some cases.
Additionally, with all this “practice”, I can now knock out a subwoofer test in under an hour. That’s 1/10 the time it takes me to test a loudspeaker.
Oh, and when you are making 8 measurements (for averaging; drops the S/N considerably), these subwoofers sound like someone is framing a house next door at the low frequencies and like a woodpecker at the higher frequencies.
Now I just have to go through the data write the review (or skip straight to the YouTube video).
Stay tuned!
I can do them quick enough, compared to the 10+ hours it takes me to test a regular loudspeaker.
I actually haven't' been wondering about any of those subs. Probably because they're so expensive and I can't just "order and test" them. But, if someone wanted to accommodate a way for that to happen then they know how to contact me. Alternatively, if we can raise enough funds through my contribution page then I'd be game. https://www.erinsaudiocorner.com/contribute/
But shipping alone is going to be expensive.
Have you ever tested any of the Dayton Reference subwoofer drivers? I've toyed with building a sub from a flat pack and a plate amp of my choice. It wouldn't be in this budget territory but would be significantly cheaper than an SVS-1000 sealed or ported.Elac showed up and testing is now done! (Unless I decide to test the Klipsch a 5th time to try to see if I can get a 20Hz reading that isn’t distorted above my noise threshold; no other issues with the other woofers).
Stay tuned!
Actually I was asking Erin @hardisj . But since you asked, the 10" HF and any of the cheap 300-500w plate amps (could even do a dsp amp on sale). And yes, I know the SVS are 12" but there ain't no way black ash or white or black gloss will be in my house, which is why I'm interested in the driver testing. I tend to be a patient finisher and have the materials for that. Even have some left over veneer that is probably about enough and I always have some partsexpress coupons. It would just need to be close enough or similar in performance, not equal to SVS but at least much better than the budget boxes. I've been impressed by the SVS teardown but they don't go on sale either except for factory seconds or refurbished only a time or two per year (plus the WAF is real).I've looked at that option several times and each time I add it all up, including obviously a comparable amp, I end up with something that costs very nearly as much but that requires me to put in a lot of work. I don't much the assembly so much but the finish is a big deal. I don't something that looks like it's been spray painted. To get a proper, clean-looking gloss black is a ton of work and based on what I've seen others do it is very, very difficult to get it to look half-decent.
Which particular combination of driver, knock-down box and amp are you considering?
I don't know if the overall product or performance is better but with the flat pack build you end up with a much more solid subwoofer. In the same price range they just don't come with that sort of cross bracing and structure.
But I do agree that the finishing the MDF is the main challenge. I built one and ended up with a good smooth finish but it took a lot of bondo, sanding primer and sanding to get there. People with more talent in that area may be able to do it faster but I was happy when my wife said "that looks like you bought it in a store" at the end.
That's the driver.Now you've got me thinking again that I should build. One thing nice about building is that if you build two, the savings are greater because the total effort and total cost isn't twice as great as for one. And for me, building two and using the speaker lever inputs is advantageous is certain respects.
hardisj said:
Plus, because you have tested some subs that Brent Butterworth has, we can interpolate from his data if it's different and use it to compare to your data for subs that you haven't both tested. So should be possible to kind of see how SB-1000 compares to the ELAC sub.
