confucius_zero
- Joined
- Nov 22, 2018
- Messages
- 541
- Likes
- 345
any news on the onkyo 9010?
Was going to say, looks like they may have an issue with coil whine that they are trying to mitigate.Keeping the coils from vibrating is probably helpful, or at least not harmful.
It is probably decent, but I am struggling to see how white paste helps with electromagnetic interference... Keeping the coils from vibrating is probably helpful, or at least not harmful.
I have one in for review....What about this guy here:
http://www.daytonaudio.com/index.php/apa150-150w-power-amplifier.html
Perhaps a teardown will reveal so!I wonder if that thing is made by the same manufacturer that made my jamo amp
.01% translates into SINAD of just 80 dB!Looking forward in seeing the results of that. 100db SNR + 0.01% THD numbers on the Dayton are quite promising!
Seems to be the number most products in that "budget" price bracket is going for in their spec sheets...SINAD of just 80 dB
any recommendation for amps with a sub-out, currently i am using the AD18 but wanna try something with a little more cleaner power!
I recently picked up an Emotiva BasX A-100, which I'm using in a desktop system driving Kef Q150's. Definitely worth looking at if you don't need source switching. Completely subjective, but to me seems to perform better than other cheap amps I have - Sure tripath boards, TPA3255, Dayton APA150 etc. Just a basic no-nonsense ClassAB amp.
