Anthem has it in their new processors!….IIRC, nobody has offered the full 48gbps bandwidth to date, and only one company as of late Autumn 2022 is manufacturing a chipset that delivers on that feature.
It would be nice to see confirmation of that. HDMI 2.1 was supposed to be 48gbps from the get go, but that still doesn’t account for every use case I’ve seen being limited to 40gbps. And then you have Analog Devices reportedly releasing the first 48gbps chipset sometime in Autumn 2022... I heard about it in November...Anthem AVM90 is supposed to be HDMi 2.1 48GB
Do you have confirmation of what Chipset, specifically, they are using, please? I ask not to put you on the spot... I am truly interested to know.Anthem has it in their new processors!
Let’s just ask them about it!Do you have confirmation of what Chipset, specifically, they are using, please? I ask not to put you on the spot... I am truly interested to know.
Curious what the distinction is between half baked and fully baked HDMI chip sets.I'm in this boat too.
I'm waiting to upgrade for when the best iteration comes available. I still haven't even tried buying a PS5 yet... and don't even get me thinking about any new games from Bethesda and the need to likely have to get an Xbox just to sate me need to play Fallout or Elder Scrolls.
Yamaha is best poised to release a processor this year. Marantz and everybody else is already to market with partially baked HDMI chipsets on their digital boards. My biggest concern then is that it will be another 2-3 years before most of the AVPs see an update for fully baked HDMI 2.1.![]()
Never mind if the only distinction is 40 Gbps vs 48.Curious what the distinction is between half baked and fully baked HDMI chip sets.
What's up, Peng?!
Other than Digital Processing and Amps... what other sources of heat are there in an AVR? Without the Amp Stage, the only real source of heat in a Processor should be the Digital Board?... but that should pale in comparison to the additional heat put out by 11 or 13 channels of Amps if I'm correct. What are your thoughts, please?
Analog Devices has one, sometime from the later half of 2022. See link I posted a few above.I thought that "full fat" 48gbps chipsets were still unavailable, and that the best HDMI 2.1 chipsets were 40gbps?
LG OLED TVs have HDMi 2.1 48GbpsI thought that "full fat" 48gbps chipsets were still unavailable, and that the best HDMI 2.1 chipsets were 40gbps?
I don't recall where I saw it, but it has been suggested that TVs are a step ahead of where the AVR/AVPs are. Part of the argument was based on the fact they have less to do than the AVR/AVP is asked to.LG OLED TVs have HDMi 2.1 48Gbps
There was talk at the time it was released, that no chipsets were available for more than 40gbps....Just looked on Crutchfield for the RZ50 specs and unfortunately it only supports 40 Gbps.
"HDMI 2.1: Featuring six rear-panel HDMI inputs and two HDMI outputs, the Onkyo TX-RZ50 incorporates an advanced video section that features some of the latest HDMI 2.1 specifications; including support for 4K/120 and 8K/60Hz video pass-through (up to 40Gbps), HDCP 2.3 compatibility, BT.2020 Wide Color Gamut, and 4:4:4 Pure Color sub-sampling. There is also a front-panel HDMI input that is HDMI 2.0 certified and supports up to 4K/60Hz."
This is why AVRs all need to be upgradable. Video and audio specs move fast and none of us should be spending thousands on a piece of hardware and then be stuck when the next board comes out or file format comes out. At these prices people won't stick with a brand or spend less if they are worried about obsolescence. I am glad my Anthem was upgradable.40gbps can pass 4k120 10-bit. 48 can pass 4k120 12-bit or 4k144 10-bit. Mostly not an issue with TVs available right now.
Is recommend watching the Audio Advice YouTube video I posted in this thread. It talks about how to set up ARC Genesis and set it so your main speakers are full range.Hi guys, I need some help I just received my AVM 70 and I cannot get the subwoofers to play with my main speakers. I have two REL HT/1205MK2 whatever I do, I cannot get them to play with my main speakers, which are Cabasse i02 the first question that I have is, how do I make my main speakers full range and how can I get the subwoofer to play the whole frequency range? I also have a REL T5i and when I connect the REL to my amplifier via the high level input than the main speakers and the REL five playing perfect but I cannot do the same with the 1205.
