bjmsam
Mount Airy, MD
In my home theater, the L+R speakers are Acoustic Research (Teledyne) AR9 driven by an Adcom GFA-585 amplifier while the C speaker effectively is the top section of an AR9 driven by the bridged channel of an Adcom GFA-2535 crossed over at 200Hz. Audyssey XT32 on my Denon AVR-X4000 balances acoustic output by boosting the C channel significantly, and though it sounds right, I would like to understand why. The seemingly relevant specifications published for both amplifiers are compared below (my speakers are 4Ω but the 8Ω specs are more complete), but I don't have a good handle on what those figures represent functionally or if volume and output are linear. Can someone help shed some light on this for me?
Adcom GFA-585Adcom GFA-2535 (bridged)
Power Rating250 watts continuous average power into 8Ω at any frequency between 20Hz and 20kHz at less than 0.02% THD200 watts continuous average power (bridged) into 8Ω at any frequency between 20Hz and 20kHz at less than 0.09% THD
Signal to Noise Ratio, "A" Weighted250 watts into 8Ω >= 110dB60 watts into 8Ω >= 100dB (bridged spec not listed)
Gain27dB27dB
Input Impedance50kΩ22kΩ
Input Sensitivity250 watts into 8Ω = 2V RMS
1 watt into 8Ω = 130mV RMS
200 watts into 8Ω = 1.75V RMS
AM-JKLWl2gu8-zf8N2CRXjaooaEQnhOu0S95XSOLjLAbzKgcACVRVvoIqaNB_62MqpBxHWbE0HR11h3S-eG5_EkLkEYZk5gBgdNZ5EpPmLrDqnxhe50-LFt2dxYKEtAPOCbrOtL1yPOK5EOzNMCM3aHnFwGiWg=w1370-h1028-no
DonH56
Monument, CO
Missing required data are the sensitivity (in dB/W/m) and listening distance to the speakers.
bjmsam
bjmsam
Mount Airy, MD
The MLP is 15 feet (4.5 meters) from the midrange driver of all three speakers.
According to the AR9 specifications:
"1 watt will produce 87dB SPL on axis at one meter."
The sensitivity also is provided in German DIN standard format: :)
"8 watts are necessary to produce a sound pressure level of 96dB at the measuring microphone, the watts being calculated from Watts=V²/R, where V is applied voltage and R is numerically equal to the stated impedance" of 4Ω.
The C speaker has only the top portion of the crossover:
AM-JKLWTDuDM7TTxudeIikM2FM9PBSN24QyOPRy3cACThqf_ltoPnkylF0eYHB9OwSfzkkTNj0g79QHYNvmcpuHTGaxzkfq-dGS7MstCvDonffTlEAqfm8UY_6Lrs5enjHWuse-W6P92u_u5DNX3rAUX14ipJg=w901-h1107-no
DonH56
Monument, CO
Does the center have the same attenuator switches, and are they all at 0 dB?
bjmsam
bjmsam
Mount Airy, MD
C does not have attenuation switches, but L and R switches are at 0dB.
bjmsam
bjmsam
Mount Airy, MD
Another data point: when powered by one channel of a GFA-5802, the C speaker plays 2dB louder than when powered by the bridged channel of the GFA-2535. Below is the table updated with its specs and XT32 adjustments for LCR balance. I used my SPL meter to verify that the delta remains constant regardless of amplitude, at least!
Adcom GFA-585Adcom GFA-5802Adcom GFA-2535 (bridged)
Power Rating250 watts continuous average power into 8Ω at any frequency between 20Hz and 20kHz at less than 0.02% THD300 watts continuous average power into 8Ω at any frequency between 20Hz and 20kHz at less than 0.18% THD200 watts continuous average power (bridged) into 8Ω at any frequency between 20Hz and 20kHz at less than 0.09% THD
Signal to Noise Ratio, "A" Weighted250 watts into 8Ω >= 110dB300 watts into 8Ω >= 105dB60 watts into 8Ω >= 100dB (bridged spec not listed)
Gain27dB29dB27dB
Input Impedance50kΩ105kΩ22kΩ
300 watts into 8Ω = 1.7V RMS
1 watt into 8Ω = 100mV RMS
XT32 GainL & R: +2.5dBC: +7dBC: +9dB
Since the AR9 is considered a 4Ω nominal speaker, each parallel circuit depicted in the crossover schematic above presumably is 8Ω nominal:
total impedance = 1 / [ (1 / top section impedance) + (1 / bottom section impedance) ]
4Ω = 1 / [ (1 / 8Ω) + (1 / 8Ω) ]
C (top section only) therefore must be drawing less power than L or R, but does that explain the lower volume considering C (top section only) is doing less work than L or R?
