TNT
- Joined
- Jun 24, 2020
- Messages
- 391
- Likes
- 274
Yes and then with another unregulated PSU, 49V but less
Thanks - did you bother to also audition the stock OP amps?
o again, with some speakers, the sound will be fine, with others, not. Depending on complex impedance frequency response of the speaker.
Thanks for the effort very interesting . I know that "old style" class D amps always had this problem , hence why you often find them in subwoofer use . Cool to see measurement's with speaker loads.
I saw one review of some older NAD >10 years ago with this kind of amps that had some setting to patch the HF behavior in software to adapt to different speakers for this very reason rising output impedance at higher frequency .
I understands that the "new style" of class D amps have the filter inside the feedback loop ? and much higher levels of feedback ?
Do we have any tread going on with modern class D amps under complex load ? are they unconditionally stable ? is some higher order effect showing up in edge cases or are they in practice just as stable or better than a traditional or lets say "typical" AB amp ( I understands that practically any technology can be driven to perfection in prototype and research , but lets stay with practical use cases) ?
There is quite some conflicting advice on this in different threads about TPA3255 amps. So far I haven't seen temperature measurements that back up this claim. AIYIMA recommends a DC48V 7.5A Power Supply
Have to correct this one. This is the case because of its topology. It's not that it's newer. The exact same topology was used over 10 years ago. The issue is that it is patented. The topology is as elegant as traditional class AB amplifier. Everyone would have been using it if it's not patented.Hi @Mnyb , yes the newer designs like NC400 and Purifi handle the output impedance issue much much better, as we can see e.g. from NC400 datasheet
The feedback loop of the "newer" designs is taken behind the filter, as you may see from the attached schematics
FYI, I have prepared a listening test with AIYIMA A07 loaded by my dummy load
https://www.audiosciencereview.com/forum/index.php?posts/635634/
It seems that there is no audible problem, however the conclusions would be valid just for the setup used in the test.
Well. While I wish I could use such design, I respect the ability to patent invention. And the time will eventually get to it and make it publicly available. That's how it is.Thats a problem in audio ”science” it a bit like alchemist secrets even the most basic concepts is either kept secret or patented, just like these THX amps , different kinds of feedback or feed forward .How could one patent that ?
Sometimes, patent is used as marketing than actually practically superior design. In this case someone else can make something as good or better without it.
