- Joined
- Sep 10, 2020
- Messages
- 100
- Likes
- 317
That seems wrong to me..
The amplifiers get left channel and right channel as input from the preamplifier.
It will those two different signals that goes to the chip input and those get amplified then on the chip output they bridge tie the load as ONE speaker output!
Seams wrong.. (and then just pass the left and right signal to the other amplifier and do the same wrong thing there. Two wrong make it not a right )
The question is two:
1. Does the switch that put the unit in BTL mode also switch so that one of the RCA inputs is sufficient to use?
2. If not and bothe of the RCA inputs is needed then surely then we need only one of the channels from the preamplifier and use a Y splitter so we feed the internal bothe amplifiers the SAME signal?
Probably easy to test with a Y cable, amplifier and a speaker I guess.
No, as long as the R/L channel is connected, it is recommended to add a tone preamp in front, adjust the A07MAX volume to the maximum, and control its volume output through the preamp.
