- Joined
- Oct 10, 2020
- Messages
- 806
- Likes
- 2,634
For a while now I've been thinking about adding a sub to my desktop system based around the Neumann KH120A. My primary motivation was not to get more LF extension (in the nearfield KH120 go relatively deep for the size), but to solve the bass dips in the 70-110Hz range caused by loudspeaker positioning. Here's an in-room MMM measurement response of the KH120 with 3-band PEQ for room correction:
You can see I had usable bass down to almost 40Hz, but a lot of energy was sucked out around 70Hz and 95Hz due to SBIR. Bass guitars were suffering and I with them
I knew I could probably fix this with a subwoofer, given that I could place it differently than the monitors.
Since I don't have a lot of space, I decided to look for a small sub with auto-off functionality. The 7" Adam Sub7 seemed to fit the bill nicely and I found a B-stock at Thomann that I just couldn't pass by
Given that there's not a lot of data on this sub on the web, I thought to provide some basic measurements. No proper CEA-2010 here though, unfortunately
Nearfield port+woofer FR measurement with highest setting of the LP filter seem to indicate the frequency response is:
The manufacturer states 32 Hz - 150 Hz in the specs, and specifically state 32Hz as the -3dB point on the product page.
Next I was interested whether running the monitors from the sub's satellite out would degrade the signal. Here's what RMAA said (direct analogue loopback of my RME Babyface compared to having the sub in the loop, with and without 85Hz high pass):
We see there is around 6dB noise penalty and a significant increase in THD and IMD.
However the worst penalty is on crosstalk (I guess as expected):
Here's the frequency response comparison:
Notice that engaging the 85Hz HP filter seems to add a tiny bit of gain.
The satellite out 85Hz HP filter slope seems to be 24dB/oct:
Let's see the satellite output distortion spectrum (with 1,7Vrms / 7dBu input):
Not terrible, but degraded somewhat vs RME baseline (link to reference).
Lastly, here's the in-room response I was able to get after integrating the sub with my monitors. I got the best results when I pushed the sub to the corner of the room, below my desk. The LP filter is set to 85Hz, monitors are connected to the satellite output and 85Hz high-pass is enabled, sub phase is not inverted. RME Totalmix 3-band PEQ is used to fix a few strong bass resonances (on the stereo out). Response would look nicer with individual EQ corrections for each channel and more bands of PEQ - but this is more convenient and sounds good to me
As you can see, I gained just a little more bass extension, but there is much less loss of energy in the 70-110Hz range. Here's a before and after comparison:
Since the sub and HP filter are footswitchable I was able to A/B test both configurations (not blind, though) and I find the difference very audible; subjectively I feel it very much improved my enjoyment when listening to music.
- -3dB points: 37Hz-143Hz
- -6dB points: 35Hz-157Hz
- -10dBpoints: 33Hz-180Hz
