My adventures in stereo
- Joined
- Feb 9, 2022
- Messages
- 344
- Likes
- 359
I have been listening to vinyl over the past year
I was briefly exposed to my uncles turntable as a kid and it ended badly with me damaging the stylus
Loved the sound but not the routine and the learning curve, also left a feeling about the fragility of the system
Had no clue about setting up a turntable, handling & storing vinyl but kept coming across many well recorded vinyl, which were not available at a reasonable price, in CD or SACD formats
One of my friends, who was a vinyl veteran, suggested a Fluance RT 85 with its bundled Ortfon Blue MM cartridge, , as a good starting point
It also did not require much assembly, the cartridge pre attached to a head shell and is very easy to assemble
Attaching the belt was also very simple, the screw on counter weight also offered no challenge
Connected the RCA cables to my parasound Z phono XRM and also the ground cable
I was now ready to balance the tonearm, having looked up some helpful videos on youtube
I was surprised by how clumsy I was in manipulating the tonearm and it took me a few attempts to get it right
Thankfully my stylus survived the ordeal with no damage
I set the tracking force to the middle of the recommended range for the Ortofon blue at 2 grams, checked it with a inexpensive digital weighing scale and then set the antiskating force to 2 grams as recommended by most of the youtube gurus
Having read that paper sleeves are dust devils, I had picked up some inner and outer plastic sleeves, which seemed well recommended on amazon
Getting the vinyl out of the original sleeves without touching the grooves, is a cool skill
All new records would get cleaned with a carbon fiber brush using a micro fiber cloth, after running around 5 rotations on the turntable
Was surprised at the amount o dust which the carbon fiber brush would pick up, even on new LP
The LP would now be stored in the plastic inner & outer sleeves and the original paper sleeves would be stored separately
I was now ready to play my first vinyl on the new TT
