That’s a group of Cool Cats…
Don't they need some lockwashers?
Seat warmers?That’s a group of Cool Cats…
Just a big tube of loctite. Hope they remember whether they need red or blue.Don't they need some lockwashers?
I think they're special bolts for Boeing; it makes it really easy to spot if one is missing.Just a big tube of loctite. Hope they remember whether they need red or blue.
1) A big tube.Just a big tube of loctite. Hope they remember whether they need red or blue.
Luckily it won't even lift off because of the weight.I think they're special bolts for Boeing; it makes it really easy to spot if one is missing.
So, where Boeing is concerned, a definite safety feature.Luckily it won't even lift off because of the weight.
Pretty sure that the 737s are jets...Luckily it won't even lift off because of the weight.
But then again, they're just props.
The bolts are props.
Yes.The bolts are props.
If that's the Vancouver version, this must be the Quebec one
Boeing problem fastener on the doors use castle nuts with cotter pins. I expected something more exotic. Not that there is anything wrong with that.
