That sucks to hear...I wonder if the chip itself died...have you tried to diagnose further?
73, N9RLI
@Toku
could you please share more info to us to understand the failure mode?
- what is the operation test? input source and output power?with what load?
- is no sound include both RCA and Bluetooth?
- did you tried open the case to see any obvious failure?
Whenever I buy a device, I do a continuous operation test with the power on for a week to check the operation.
I used to have a lot of measuring instruments in my radio & audio shack, but now I have almost disposed of them at the suggestion of my family due to aging.
Therefore, detailed measurement check cannot be performed. Currently, I only have the legally required measuring instruments for the radio stations I operate.
I used to work at a large Japanese manufacturer, designing equipment for TV broadcasting stations. Therefore, I had a lot of equipment even in my private life. And elucidation of such troubles was my specialty.
Unfortunately, there is no schematic of SY-DAP1002, so many checks are difficult. Still, if you have an oscilloscope, you can track the signal line, but now you can't.
So far, I have only opened the cover of the amplifier and tested the soldering condition, the mounting condition of the parts, and the vibration test.
If you switch the connection from the silent SY-DAP1002 to another Chinese amplifier, it will work normally.
I also tested BT, but I can pair it, but there is no sound. Similarly, BT works fine with other amps.
The operation with the volume knob and the LED display are normal.
If you have any advice for checkpoints, I would like to implement it.
The red LED of the power supply blinks slowly when it is OFF, and it lights up brightly and continuously when it is ON. Is this correct?
The operating environment conditions of SY-DAP1002 are as follows.
RCA input source: Topping E30 & SMSL M500
BT input source: Oppo mobile phone R7
Speaker used: Home made
No1 (Tangband 10cm Full range unit 6Ω)
No2 (Tangband 12cm Full range unit 4Ω)
