might as well print a room with speakers integratedMy suggestion would be to print a pair of Revel Salon2's. Might as well go big.
its is true that there can be a variability in the process. however you can characterize that and develop design allowables with consideration. more so a concern with critical structural components and fatigue. It is true that you cannot expect to get the same properties you would get from the equivalent wrought or cast form of the printed alloy. However there is growing data published for this as well...I had a long convo with a materials engineer about 3D printing. You can print quite dense and strong objects. The main issue is that the properties you design for and expect can be wildly off. Whether or not this matters depends on application.
General note. I have no advice other than to keep this in mind.
I printed certain parts for my Linkwitz LXmini, the bits that relate to the tweeter - tube, standoff, part that holds the tweeter in the tube.
Cabinets etc. would likely have vibration issues I suspect? Using for complex molds makes sense though.
JonathanView attachment 161881
Agree. Go big or go home. They have whole communities with 3-d printed houses. Might as well.might as well print a room with speakers integrated
Any idea on what might be an easyish design to start with? Has anyone here tried 3D printing a speaker before? I also thought after my first try I might use the 3D print to make a mold for some concrete speakers, which could look less cheap and probably sound better.
Hi,
It has been some time since your post, but could you give some info about your printing material and parameters?
How does the box behaves? Does it resonates?
Would you go again with enclosure printing?
