Terplover
- Joined
- Dec 14, 2024
- Messages
- 71
- Likes
- 86
I thought it was about time to start a thread on my second 3D-printed speaker build! I'm not an expert in speaker design or acoustics, so I’d be genuinely grateful for any tips, feedback, or advice you’re willing to share.
After being really impressed by the results of the D-Note 3D-printed speakers,
I decided to go for another printed project. The plan is to build a 2-way speaker using:
A few days ago, I came across the Ascilab C6b and instantly fell in love with the clean, all-white look.
I fired up Fusion 360 and designed a ~15L enclosure with an integrated waveguide. Because of print size limitations, I’ll split the box in half and align the pieces using metal pins for proper assembly.
Now, here’s where I could really use your input:
Tweeter Horn/Waveguide Shape
Found a Oval Waveguide for the SB26CDC, but I don’t like the look. Can I simply "cut" the oval guide in half and rotate the profile to make a round horn? Or how would this change its behavior? I’m not experienced enough to design a proper horn from scratch.
Wall Thickness or Plaster of Paris?
I considered printing the enclosure and then filling the walls with plaster of Parisor just print with enough infill. Costs almost the same. Price for Filament is around 6€/KG. With 17mm walls i need 4kg per Speaker. With 20mm for Front an Back and 10mm for the rest, It,s around 2,9kg. With Plaster of Paris its still 1,6kg + The Plaster and additives ~10-15€
I found a lot of info online about infill percentages and number of walls, but not much on actual wall thickness.
The D-Note (with a smaller 5” woofer) had ~8 mm side walls and a thicker baffle, and it sounded great — no resonance or leakage I could detect.
Would something like 20 mm for the baffle/front and rear and 10 mm for the sides be a good compromise between performance and material use? In my first design, I added inner support beams to improve rigidity.
Internal Diffusors Worth It?
Is it worth printing some internal surface texture like small waves or multiple beams to break up reflections?
Tweeter Chamber Separation?
I read somewhere that some designs isolate the tweeter from the main volume. Is that worth doing? I haven’t seen it implemented in many builds.
Thanks for reading through all of that! I’m really excited to continue this project and would love to hear what you think or what you would do differently.
- SB Acoustics SB17CAC35-4 (woofer)
- SB Acoustics SB26CDC-C000-4 (tweeter, with horn or waveguide)
- SB Acoustics SB15SFCR-00 (passive radiator)
