Yamaha MX-2 terminal change
Knobstler
Is there a way to change the binding posts on my Yamaha mx2 to accept banana plugs or spades instead of bare wire?
Yes of course.
You can remove the cover, desolder the stock connectors, find suitable connectors of your preferred type, and solder them onto the PCB instead.
You may have to modify the rear face plate to make the new connectors fit.
Yes of course.
Oh i was hoping there was a way withouth soldering. I guess i have to find someone who can do that or i leave it as is
problem solved I found some smaller spades from viable which fit like a glove
