WolfX700 Measurements of Topping Pre90/Ext90 Preamplifier/ Extender
Output impedance changes across the range. 0 at maximum and nil position and 1/4 of the resistance at 50% position. And in between else where. You can calculate it but there's no way to minimize it without changing topologies or adding a buffer.
ic, can I understand how's the calculation? as I am interested to get one, not trying to optimize or lower that, but I can try to avoid those >1kohm output impedance values and use digital solution from dac instead to feed my 8030C instead of using the high gain active preamp like I currently do
Just use as normal, it should be fine. As nothing is bothering you.
For most cases you may not go over 50% position (which is usually about 2-3 o'clock already). In normal use it's under 12 o'clock(which is about 25%) right? So no big deal for the most part. When it's at noisier position it's probably really loud already so it won't be so audible either.
ic, that's perfect for me then, I am really liking the Khozmo look and then the volume currently I use is either with dac and the digital volume is at 20-30, and paried with a DACT modded Taurus with 26db gain I always keep the knob at -50 to -60db depends on song and digital volume at 80-100, if so the 48 step khozmo would fit as the sole preamp or use as a pre for taurus if any noise occurs
@Yohn,
I understand that impedance mistmatches are an issue. But one can't use that argument always as is done very often with jitter in DACs to justify anything.
This is a very good (professional)DAC with its own volume control:
Now with the GoldPoint, or maybe whatever stepped attenuator:
Noise floor with the external attenuator is lower. So, using normal cable lengths as most of the hobbists here do, what's the benefit of passive mode in the Pre90, the Shiits or whetever, over a humble stepped attenuator?. Looking at this graphs I get the impression that those pre-amps look like over-engineered for something ordinary resistences can do.
I'm sure I'm missing something, but I'm struggling to understand what. Of course, I'm always speaking of passive attenuation.
@Cortes, the only thing you're missing is most active preamps have high input impedance and low output impedance so users don't have to worry about compatability of components.
If you're going to have 2K input impedance, there's absolutely no reason not to go passive. Max output impedance of a 2K pot is only 500 Ohms! I use a 10K pot in my Goldpoint passive to be more forgiving of the source component.
@Yohn,
These aren't comparable. The pre90 which I did not talk about is not comparable to things like that. You get good performance and some voltage gain as well as low output impedance but more importantly it's the input output switching, saved volume, remote, screen etc. Also you get way more steps with relay controlled here. A good stepped attenuator will cost 200 dollars itself, for a passive preamp on the market it will likely be 600+. And I don't want to say about this but pre90 will be cheaper than that with all that extra functionalities.
If you include regular potentiometer volume control then L30 is just over 100 dollars with pristine signal path.
The beauty is that you can choose whatever that fits your use case. And it's fine. I'm not here telling everyone to buy a pre90.
Hi @JohnYang1997, is there a chance that you will produce the A90 with a remote control in the near future? I see the A90 as the ideal ultimate headamp/pre combo solution for a reasonable price, but the remote control is really missing here.
Hi
Thanks for this review !
For a Pre, THD+N and/or IMD+N vs level is very important, IMO.
Is there a chance you measure that ?
(I know. We always want more...)
EDIT: OK, I see you published dashboards at -20, -30, -60 and -90dBr
Not exactly the plot we're used to, but that gives enough of an idea.
I suppose I can just get the ext90 only and use with existing amp?
I think I saw commented that an idea was to add support to the A90 for the extender, but the extender uses a proprietary interconnect - many pins - to connect the main unit to the extender.
So unless a future device from Topping comes out that supports the extender interconnect cabling it will only work with the Pre90.
I know about Topping's power amplifier development plan-a design that is approximately twice the height of the Pre90, the same width and slightly deeper.
In fact, I also took the time to give a suggested 3D design of the appearance (hope that Topping can finally adopt this design)
I am also looking forward to this product...
class D? class ab? class h?
What is the maximum output voltage (assuming you feed it with 4V XLR)? Does it have fixed gain?
There are these passive Stepped attenuators in US
https://goldpt.com/sa2x.html ...
they do not specify the attenuator impedance ... i guess they provide different values on customers' demand
Personally the idea of an "universal" preamp is very understandable ... a preamp for all seasons. But if i had a unit with excellent performances i would select a source compatible with that preamp. There are many quality dacs with very low output impedance of few ohms that should work just fine
