WolfX700 Measurements of Topping Pre90/Ext90 Preamplifier/ Extender
As I said, and you need to understand, 47K-50K has been the defacto standard for many decades. Defacto means it comes into being through use, adherence and general agreement. One guy standing on the sidelines saying 2K is fine isn't going to change a thing.
Literally hundreds of millions of CD players all specified 2.0V out with load impedances required of over 10K minimum to ensure perfectly flat responses and lowest distortion. Tuners require 20-50K. Phono stages need 10K or greater. DVD players need the same.
There is no debate. 2K ohms is ridiculously low and when you've made a few more preamplifiers, you'll understand. :)
And I like the look of the preamplifier and the input extender. The display looks a bit blocky in the pictures but likely it looks better in the flesh.
RCA in is 10K.
One question is mostly ppl use the pre amp as volume control, interesting to know what the A90 pre SINAD at it's lowest 10-15% setting will be
At those level there sure isn't distortion contribution. All is noise. So 50mV SNR measured by Amir mostly described what you are asking for.
IC, seems the SNR still got like 108dB of SNR, may I ask if the relay is located before or after the gain stage to attain this level? I think the noise floor in the dashboard is like -150dB, so 50mV and SNR still retaining 108 dB is impressive
Who is the typical buyer of Topping's product ? The "classical" Hifist with bunch of (often less performing) old gears ? I don't think so.
The thought that the typical buyer needs this to switch between different Topping DACs is flawed IMO. What other use cases are there? Topping should have done more marketing research instead of trusting engineers to make these decisions. This stupid low input impedance will spook a lot of potential customers and the fact that Schiit Freya S is no longer indicates that the preamp market is already thin.
The choice of a 2 kOhm input impedance for a line-level XLR input is weird indeed. That would be a typical value for a mic input (which are often 2-3k). At line level, 20k would seem to be a more typical value in my experience. I could still see 10k or 6.6k working OK when driven by halfway modern opamps, but 2k would require parts with quite a bit of oomph, particularly at high levels.
It's not exactly good for practical input CMRR either, which is going to be an order of magnitude more sensitive to source impedance imbalance. I presume the input stage is a standard 1-opamp bal / SE converter topology? Consider upgrading to the 3-opamp buffered version then, with 1 Meg input bias resistors for the buffers (given the unity gain application, I'd select something with superb common-mode linearity for those, maybe some of the CMOS input OPA16xx).
I know about Topping's power amplifier development plan-a design that is approximately twice the height of the Pre90, the same width and slightly deeper.
In fact, I also took the time to give a suggested 3D design of the appearance (hope that Topping can finally adopt this design)
I am also looking forward to this product...
I hope they consider potential buyers that would be matching the D90, A90/Pre90 with the power amp, at this price point aesthetics matter as well as functionality.
5532 4562 1612 all having no issue driving 600Ohm load
Then that means adding more relays when input disconnected, changing different opamps and add more opamps for worse performance. While there's zero issue pairing with majority of new designs with current configuration....
The only devices that may have issues are the ones with small DC blocking caps at balanced output.
The ones that don't have caps will have zero issue no matter what output impedance is.
The ones that have 100uF or higher electrolytic caps will have zero issue.
Output opamp is not a concern, jellybean 5532 will drive 600ohm with zero issue. Let alone current lm4562, opa1612 etc.
More and more details about this preamp...however still nothing about a launching date:(
There are these passive Stepped attenuators in US
https://goldpt.com/sa2x.html
which look imposossible to beat. No channel imbalance. Better volume control than expensive professional DACs.
https://www.superbestaudiofriends.o...ssive-attenuator-technical-measurements.7303/
Hmm. No output buffer. High output impedance at certain ranges. more interference. Almost always high resistance type, high noise at certain range. Only less than 50 steps.
Lastly....the ones in that site are expensive. You can get equivalent or better ones for 100-200 dollars.
Or just use digital volume from dac and ditch these poor performing ones altogether.
I'm sure you are right. All I know about preamps has been from my readings today. But why poor performing?. Measurements are stellar. I don't see the pre90 is better, maybe the opposite. Why to add complexity if not necessary?. The measurements comparing the volume control of the Dangerous Music Convert-2 DAC with the GoldPoint are impressive.
BTW, I payed attention to this because I'm looking for something with multiple XLRs outputs with volume that does not screw up the DAC signal. From what I've seen these are preamps but there are very few with multiple XLRs outputs.
BTW, I payed attention to this because I'm looking for something with multiple XLRs outputs with volume that does not screw up the DAC signal. From what I've seen these are preamps but there are very few with multiple XLRs inputs.
The performance of these passive types is only good near max or near nil. You can read Benchmark's description for their LA4 so you don't need to take my word for it. Passive types always have major trade offs between input impedance, output impedance, noise performance, interference and distortion.
I have the Goldpoint SA1X. Bought it several years ago in 10K model. They are very nice but super expensive. No remote either.
10k is middle of the road while it's relatively clean but can get noisy and interference near middle impedance position (not half way position) as the impedance of the connection to the next stage is much larger. A simple buffer theoretically will clean this up(basically what L30 and A90 do in preamp mode) but as it's active, so any design decision will have large impact on the performance. Under this context, passive preamps are safe options. But mostly don't really have benefit over digital volume/preamp function in DAC unless you attenuate really deeply (basically when the power amp has too high gain)
