WolfX700 Measurement of Topping A90 Headphone Amp
w1000i
Jubail SA
it seems this amplifer have extremely high slew rate. does H. slew rate benefits audio quality ?
Martin
Cape Coral, FL
Pretty cheesy...
Does it really have a $999.99 list price?
Martin
maxxevv
Sean_S
I have benchmark dac3, which voltage jumper should I use on it for SE out to the a90? Does a90 have better snr when receiving more voltage on input, or best with ~2v? Thx
JohnYang1997
China
As A90 has a volume control. The SNR of the upstream component will be preserved. The higher output of the DAC3 won't give any SNR benefit if not more distortion (potential). But we usually test on 5V in for SE input. So take that as a reference point. There's no issue when the voltage is within the input range. I recommend using Mid gain setting on A90. So choose the DAC3 output level to fit the loudness you want.
LuckyLuke575
Germany
This is really a long and memorable vacation ...
Mainly for well-known reasons ... I haven't released any measurements for a long time
Logistics was completely stopped ... R & D and manufacturing were also completely halted ...
God ... this is really a boring holiday ... I have been bored to spend the whole week to adjust one of the equipment I made before (for example, to make the THD+N vs Freq curve of the left and right channels basically the same, and the harmonic components are also consistent);)
For the coronavirus, I was almost 600km away from the center of the outbreak. In terms of government's epidemic prevention measures, in fact, I could hardly find anything to worry about-----Good social order and basically good supply in the supermarket-one thing to complain about is that Coca-Cola in the supermarket near my house is always in short supply:facepalm:
well, let's get back to business……
Before the Spring Festival, I knew that Topping was developing a new headphone amplifier and made an appointment with them for measurement.
The thing was finally mailed to me two days ago (thankfully they started working).
This is a compact unit. The workmanship is not exquisite, but there is nothing to complain about. Topping's family-style design (the size is the same as D90)
What I like very much is that the Power supply is built-in, making the whole system look simpler (it is always uncomfortable to hang a power adapter outside)
It's a headphone amplifier and preamp integrated product, this design may be very suitable for desktop users? (A small combination of active speakers and headphones)
First I will measure the headphone amplifier part:
I start with a medium gain, 4V input
Wow! ... I was a bit shocked ...
I feel that it is not the device under test that restricts the measurement results, but APX555.
In the case of 5V input / UNBAL output, I got 123 SINAD!:oops:
This is crazy!o_Oo_Oo_O
For comparison, this is the AP Loopback:
How does THD + N change with frequency?
Attention! The bottom of this chart is not 0.0001% as usual, but 0.00001%!
Alright, let's get on the load! See the results under load!
SNR:
THD+N vs Level
I was having difficulty measuring the maximum output ... because the protection circuit is very sensitive, it cuts off all outputs at the moment of overload ...
I got a maximum output of 6.5W with 33R (BAL Out) in dashboard mode!
In this case, SINAD is still as high as 110db.
The results of the previous test were so crazy that it made me feel boring to release things like frequency response (such a device is almost impossible to have problems in this area)
Of course ... Since the volume is adjusted with a potentiometer, there must be some problems with channel balance.But it is said that the final version of the gain will be adjusted to -9 0 9 (the one I got is 0 6 12) should be able to adapt to various headphones.
End of headphone amplifier measurement ... output impedance(0.37R):
Preamp section: As good as the headphone amplifier section!
This is one of the best headphone amps on the market no question.
omgezkoren
is topping a90 a better amplifier than drop thx 789 and monolith aaa 887? topping a90 is now the best measuring headphone amplifier? currently topping dx3 pro v2 i use akg k612 pro and meze 99 classics headphones. great improvement can be achieved if the dx3 pro v2 + A90 were the source, or is the dx3 pro v2 already such a good device that they wouldn't notice a difference?
reiserfs
Ordered one from Hifistudio in NL, since Audiophonics didn't allow pre-orders. Looking forward to it.
THAndy
The measurements of the prototype do look a little better than the THX amps. But it might be worth waiting until people have some experience with production units, including measurements. There can be changes made since the prototype, and there can be little unexpected details of people's experience that make a difference.
VeerK
NYC
We are probably in the realm of inaudibility, buy the A90 for the features and aesthetics, more so than expecting to hear incredible differences. That being said, this amp is so far the closest to the mythical “wire with gain” and I like to reward good R&D by purchasing excellent products.
Doodski
Patrick1958
Belgium
DX3 pro sinad 105/106
Topping A90 sinad 121
Quality is determined by the weakest link. Imo no improvement. The DX3 pro will not suddenly measure better connected to a high performing amp.
What you most probably will get is more power, that's it, but more power doesn't translate to better sound.
omgezkoren
so would i buy a Topping A90 in addition to the Topping dx3 pro v2? wouldn’t it be a more dynamic, clearer, more detailed, bigger soundstage? is it worth buying a Topping A90 only if you have a sinad DAC 115-120 worth it?
