They don't look bad at all, but yeah, kinda pricey.Not if you don’t turn up the volume too loud. But this is also the case with a lose power amp. A clipping amp can always damage speakers.
Anyway, why spend so much money on an amp? Seems like a waste…
Looks doesn’t tell you anything. The one Hegel amp tested by ASR wasn’t very good:They don't look bad at all, but yeah, kinda pricey.
Hmmm. Yeah, sucktastic. Well, they claim 0.005% THD for the H390.Looks doesn’t tell you anything. The one Hegel amp tested by ASR wasn’t very good:
Hegel H95 Review (Streaming Amplifier)
This is a review and detailed measurements of the Hegel H95 integrated amplifier with DAC and streaming support. It is on kind loan from a member and costs US $2000. The H95 looks pretty nice: I really like the large, high resolution and very responsive graphic display. What I don't like is...www.audiosciencereview.com
Short answer: no. Longer answer: nooooo
Seriously, just listen, and don't turn it way up to the point you hear distortion. Unless you have little kids that will do that (or inebriated "friends") you're fine.
You can get plenty of better amps for far less money. Spending it on speakers is a much better investment sound quality wise.Yeah the amp is future proofing for other speakers, and I have some SVS Ultra Towers and 200W rated B&W speakers. I want an amp that’s a little over powered for fun sake, but noted that the Kefs were also 4 Ω (min. 3.2 Ω) nominal, so I was a little nervous.
They are from the same family of companies. I would also say it if I could sell two products instead of one.Kefs are reported to go well with Hegels in terms of synergy, but the speaker / amp combos are usually a closer match than this will be.
Awesome. I don’t really need to choose, so if you have great speaker synergy suggestions, or the better amps for less money, let me know!You can get plenty of better amps for far less money. Spending it on speakers is a much better investment sound quality wise.
Awesome, thank you and good to know. I hear all these folks saying one amp has a better sound stage, is warmer, or more clinical blah, blah. I’m new, so I don’t know how much to read into it. Thanks for the link, I’ll check it out.Check out the review index: https://www.audiosciencereview.com/asrdata/ElectronicsallList
It all depends on the needed feature as well. You can also go for a power amp and a DAC if you only play digital sources. You can also get a DAC or amp with room correction. That would actually elevate the system to the next level.
As for synergy: that’s mostly a myth. An amp is not an EQ instrument. It just amplifies and most are good enough, probably even the Hegel. Any decent amp works with any speaker. If it doesn’t sound good, it’s the speaker, not the amp.
I second this choice.Not if you don’t turn up the volume too loud. But this is also the case with a lose power amp. A clipping amp can always damage speakers.
Anyway, why spend so much money on an amp? The amp is 2.5x the price of the speakers. Seems like a massive waste…
For that kind of combined money you can get a pair of Genelec 8351. Saves you the amp and DAC and end up with a better speaker overall.
This amp is veeeeery interesting thank you again. Anymore gems out there you’d recommend let me m is. I don’t mind going up in price a bit, but I definitely would like good value for the money.As far as SINAD at 5W the Hegel amps in general are green good, but not excellent. Add the price and the deal is not so good. Not terrible too, just think there are better options out there.
IMO an RME ADI-2 DAC fs + NCx500 amp for around 2.5k USD is a lot better in both technical performance, power and features. And use the price difference to get a streamer and a subwoofer.
Awesome. Thank you I’ll check those out!If you want a nice chassis for you amp consider Boxem or Apollon as well, maybe their Purifi amps too. If you have the space, with the money spared you can even get a tower speaker like R5/R7 Meta maybe, and use the subwoofer cut really low (if needed at all).
