- Thread Starter
- #81
He's taking the hiss.now now
I'm going to endeavor to put this in the least snarky way that I can: @Steve_404 you sound like ChatGPT (or whatever it's called). The only non-AI sounding phrase in the above is "There are certainly brands..."That's a great question, and one that is becoming more and more relevant as we continue to see an increase in the use of active speakers. When it comes to the issue of e-waste, it's true that failing amplifiers can often be the culprit behind active speakers becoming obsolete. This is definitely a concern, especially in light of the push for more sustainable practices and reducing the amount of waste that ends up in landfills.
However, it's important to note that the situation is not necessarily bleak. There are certainly brands, such as Genelec and Neumann, that have a reputation for producing active speakers that offer long-lasting and reliable performance. These companies often use high-quality components and rigorous testing processes to ensure that their products can stand the test of time.
In short, while the risk of active speakers becoming e-waste is something to consider, it's also possible to find speakers that are designed with longevity in mind. By making informed choices and choosing products from reputable manufacturers, you can help minimize your impact on the environment and ensure that your speakers serve you well for years to come.
Authorized replacements are still available from Soundsmith, and I believe they'll also retip some of the older cartridges for which they do not make replacements.Not just speakers, some very nice vintage B&O turntables go for a pittance because the their proprietary cartridges are nowhere to be found. I'm sure there are other examples as well.
Anecdotal reports are useful, but necessarily retrospective, and I expect the numbers from the last twenty years will be different than the next twenty.How many broken active speakers have you seen in your life?
actually ppl throw away passive system components just as frequent as actives at the price points, for most cases they are ditched as e waste not because it breaks, but something newer and better comes out! and you have to think about that passive stuffs usually get much thicker and fenizer cables and other accessories due to how the market works, there are much more metal, extra electronic headroom in the power amp used than a well designed active, imagine how many of the amps you have to throw away in an active like a pair of genelec vs a stand alone amp? not to say the more inefficient tube amp with all those exotic tubes rollingActive speakers would represent an increasing amount of, potentially unnecessary e-waste, if the trend here is anything to go by. I replace my smartphone less frequently than many and would prefer it if they lasted longer, but a loudspeaker is essentially a very simple thing, a modern computer is not. It may not be within the realm of feasibility to make computers last much longer than they do, whilst providing adequate performance. It is certainly far easier to keep speakers from becoming waste.
No, that is incorrect. Depending on the fault, it may not be particularly labour intensive, expensive or difficult to fix. Repairing can often allow a superior product to remain running, rather than buying a new, inferior product for the cost of repair.
I'm trying to understand your approach, perhaps we are just different people. If I like a pair of speakers now and have space/use for them in the future, I will continue to use them. Do you buy new products purely because things 'get old', even if performance is still satisfying? Loudspeakers can give decades of good use without much in the way of deterioration (at least that which cannot be easily fixed).
I understand that there are performance gains with active speakers, but from a green point of view, is it good to take a simple thing with good longevity and make it complex with rather more limited longevity?
I think the point was that Active speakers contain e-waste.actually ppl throw away passive system components just as frequent as actives at the price points, for most cases they are ditched as e waste not because it breaks, but something newer and better comes out! and you have to think about that passive stuffs usually get much thicker and fenizer cables and other accessories due to how the market works, there are much more metal, extra electronic headroom in the power amp used than a well designed active, imagine how many of the amps you have to throw away in an active like a pair of genelec vs a stand alone amp? not to say the more inefficient tube amp with all those exotic tubes rolling
The Salon2s will be hard to beat. But if you dare, go listen to JBL K2 S9900s. Different beast, but equally spectacular.Yeah, because over the years it's freaking expensive. Thankfully the Salon2s got me off that bus ride. I've been tempted over the past 12 years, but never blew another wad replacing them. The last time it was the Genelec 8361/371 combo. I'm so glad I haven't found a way to hear them yet.
E-scrap is one thing to worry environmentally but the major issue is the unregulated production.
If you really worry about things search about the production ethics.
I know I did,I want my kids to live as well as I do.
So true.Unregulated buying i'd say
Define the boundary between need and want. By the strictest parameters, probably a full 90% of the people using this forum never "need" a piece of audio equipment again.Try buying stuff you need not what you want.
well actually this is precisely why e-waste are generated, and I would argue passive users create more e-waste as there are more "points" they will be tempted to upgrade/change, compare how many caps/transistors are in an active speaker, then look at most fancy passive gears with overbuilt or littered with exotic parts you will see how much e-waste is created when one is disposed. Now if you see how many ppl throw away old gear which are fully/mostly functioning you can see the trend.Define the boundary between need and want. By the strictest parameters, probably a full 90% of the people using this forum never "need" a piece of audio equipment again.
How do you know that?Define the boundary between need and want. By the strictest parameters, probably a full 90% of the people using this forum never "need" a piece of audio equipment again
This will sound so ludicrous to those who have not handled Genelecs that they will believe you are joking. I don't recommend that method of transportation, but they really are this solidly built.I once dropped a Genelec 8351 down a flight of stairs - it bounced end over end, smashed a window, and landed in the parking lot. We tried it and it worked fine. Still does.
well actually this is precisely why e-waste are generated, and I would argue passive users create more e-waste as there are more "points" they will be tempted to upgrade/change, ....
.... compare how many caps/transistors are in an active speaker, then look at most fancy passive gears with overbuilt or littered with exotic parts you will see how much e-waste is created when one is disposed...
...Now if you see how many ppl throw away old gear which are fully/mostly functioning you can see the trend.
