I really just don't see it as easy.Easy. Take a 3-way with 4th order (analog/IIR/minphaseFIR) slopes ~300Hz/3000Hz.
Take the 300Hz & 3000Hz crossover points.
300Hz requires a c2c between low and mid of 11.3" at xover freq....but for ripple free summation, i try to stay with 1/4wl thru the critical summation range, which depending on how wide you define that, gives the c2c needed.
In the case of an LR4 @ 300Hz, and using summation to -20dB which occurs at 520Hz, I use that wl for c2c which becomes 6.5".
3000Hz requires 1-1/8th" c2c at xover. Seldom ever realistic i think....and forget about c2c at -20dB with LR4 (5200Hz)
I've read the Grimm paper a number of times. Honestly, i think it's much of a marketing piece for the strategy used on that speaker, as it is a technical design piece.
It's all a good step in the right direction, not trying to say it isn't. But the 'trainwreck" is overly contrived imo, and the FIR overlay is being used for reduced cost/complexity
