I don't think you can use that DC speaker protection for D-class amplifiers because it seems that the (-) connectors for the left and right channels are connected and that shouldn't be in D-class amplifiers (like in A / B class for example.Do you use such a relay?
https://ja.aliexpress.com/item/1005002305755967.html
Even with this product, the negative terminals of the L/R channels are connected together, so it cannot be used with BTL/PBTL class D amplifiers.
I know I also need a switch.It is difficult to prevent pop noise by simply adding the speaker protection unit to your amplifier.
Even if you use this unit, you need to add a power switch between the DC connector and the amplifier board as I explained last time.
If you want to know the reason, I will explain later. I'm going to bed already.
To eliminate the power-off pop noise, it is necessary to detect the power-off as soon as possible and turn off the speaker output.I know I also need a switch.
can't use this relay understand.
I contacted the manufacturer. He said. "Mute can be set to a high level of 1.5V to 12V to MUTE it before shutdown."
In the first place, these products are for preventing pop noise when the power is turned on. It is not useful for eliminating pop noise when the power is turned off, which is a problem this time.
Read the description carefully, they are completely separate.
Details:
UPC1237 power amplifier speaker, speaker, speaker protection circuit board
Turn on delay about 5 seconds
Audio DC output protection
Each channel uses a piece of UPC1237 special protection circuit chip
The resistance of the protection board uses imported resistance
"This version supports BTL amplifiers. The left and right channel circuits are completely independent. When using BTL amplifiers, you need to connect 2 independent power supplies"
Hanzao's amplifier board has the same symptom for both TPA3255 and TPA3251.Thanks, everyone.
It's difficult to make a circuit. There is also deterioration in sound quality. So I buy a new board.
Does Hanzao3255 also have pop noise?
I want a board with excellent sound quality. Better than Shui Yuan TPA3255.
Does anyone compare 3255/3251 to UCD32MP?
In the case of MA12070, which is better, the board or the finished Sabaj product?
Thanks for the detailed explanation.Hanzao's amplifier board has the same symptom for both TPA3255 and TPA3251.
I bought four MA12070 chip amplifier boards and experimented with them.
This amp board is also difficult to handle.
I have tried both balanced and unbalanced connections, but the balanced connection is stable, but the unbalanced connection has a habit, and depending on the DAC to be connected, the operation becomes unstable and noise is generated.
Like the Shui Yuan TPA3255 amp, this amp board can also eliminate pop noise when the power is turned on by adding a capacitor. There is no pop noise when the power is off.
I bought three SA300s as a completed amplifier product with the MA12070 chip. The operation of SA300 is very stable.
I also bought two new BRZ HiFi mini amps, which sounded good but didn't turn on the day they arrived. I also purchased a BRZ HiFI TPA3255 amplifier product, but it also did not turn on. There are risks associated with purchasing BRZ HiFi products.
The 3e audi product is the most stable of the TPA3255 amplifier boards I have purchased so far. I'm also very interested in JLE's products, but I haven't purchased them yet.
Please see the following HP for the data of Sylph-D200.Thanks for the detailed explanation.
I would like to buy a Sylph-D200.
Do you have the size and wiring diagram for this board?
Which is better, Output Inductor?
Hi Guys,
I am setting up a new amplifier. I am in fix between Shui Yuan, 3E Audio and Hanzhao board. Can you guys please suggest, which one is the best out of three considering stability and audio quality.
Can you guys also suggest the power supply accordingly! The MeanWells are large, so looking for compact power supplies.
I bought the Shui Yuan a few montrh ago and I am quite happy with it. But I would not recommend it due to very cheep connectors which are just not nice to work with. The power and speaker connectors feel yery cheep and no not accept thick wire. I really could not build my amp as I wanted it to build. The Shui Yuan is just very small and very cheep.
The 3E Audio seems to be much more substantial. Its also more then twice the price of the Shui Yuan. 3E Audio is also active here on ASR and posts their own measurements.
