Hi all,
I am looking for a tpa3255 amp with bluetooth to use in a basement/garage set up. I have been using a SMSL SA-50 for a couple years down there and it was pretty decent. I just picked up an Aiyima A04 and A07 to test out and will be replacing the op-amps with OPA1656's when I get them. So far they sound pretty good, but havent had a chance to really test them out yet.
I would like to get a similar amp to the A07/A04 that has bluetooth capabilities. I need something completely assembled off the shelf since I dont even own a soldering iron and I really dont know much about capacitors or inductors. I can replace the op-amps though, seems simple enough. Based on a lot of reading in this thread and many others, the three I am considering are as follows:
3e audio -
https://www.aliexpress.com/item/1005001849585611.html
Seems to be the front runner based on what I've read about the quality of the components.
BRZhifi -
https://www.aliexpress.com/i/4000970577819.html
Seems like an ok unit, but I read something about the power supply not being grounded properly and could be a fire hazard?
Aiyima A08 -
https://www.aiyima.com/products/amplifier-aiyima-a08-tpa3255?variant=33044336541771
This is pretty new and there isnt too much info about it yet. I saw daniboun mentioned its another tpa3255 unit with bad caps, but how does it compare to the other units? Does it have the same issue of grounding the power supply that the BRZhifi has?
Any info would be helpful in comparing these. Thank you in advance!
