That arrived today....
Nice! When can we expect to see those measurements?
The specs look good. What I am worried about is that it will not measure well and I will be out $70.Hi Amirm,
Would this be interesting ?
Affordable dsd dac with very uncommon coaxial output for some who wish for flexibility of headphone but yet able to use at home system to a higher quality dsd dac:
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/123246231925
TIA and best regards.
Richard
Good grief. These are become crowdsourcing projects now.Massdrop Grace SDAC Balanced (summer 2019...)
Btw, seems like matrix spdif-2 was never measured as I am deciding between the diyinhk pro3z and the more well equipped matrix spdif-2 albiet at usd379 vs usd216 ? I have the to be returned loaned pro3z with uniquely xmos216 as a usb-spdif bridge in my rather hiend car audio system which sounds great and was hoping matrix spdif-2 will sound at least just as great if not better.
I also have the hifime UH1 and smsl x-usb that sound significantly more veiled and lifeless when compared to to pro3z .. especially the UH1.
S/PDIF signal really shouldn't impact sound quality, at all, on anything but the shittiest dacs that perform next to no filtering on the incoming digital signal
The matrix spdif2 is really quite pricy honestly. Btw, amir already measured 4 spdif converters so far in case you didn't see them all:
https://audiosciencereview.com/foru...-of-gustard-u12-usb-to-s-pdif-converter.2166/
https://audiosciencereview.com/foru...s-of-smsl-x-usb-digital-audio-converter.2432/
https://audiosciencereview.com/foru...nts-of-schiit-eitr-usb-to-s-pdif-bridge.3753/
https://www.audiosciencereview.com/...llo-digione-signature-and-diyinhk-pro3z.4660/
Iirc the topping d10 also had its spdif output tested somewhere on another topic.
@richard_crl032 if I were you I'd simply buy the pro3z since you were already quite happy with using it. Why spend more?
Getting the matrix and/or a fancy power supply is really just buying into wild people's claims on forums, neither of this has been verified to really make a difference, you are betting a lot of money on questionable information.
They are quite pricey so too expensive for me to buy. I do get fair bit of requests for them though. How about contacting them and telling them you won't consider their DAC unless they send it in for measurement? More and more companies are doing that these days.Measurements from Questyle Audio entry-level DACs would be great.
It is very nice looking. Too expensive for me to buy it but I just sent them an email to see if they will provide one for review.I'm curious about the hidizs DH1000; it's a portable, dual balanced headphone amp/dac that costs less than 300$
Love the sleek look with the minimalistic design and tempered glass.
Here you go: https://www.audiosciencereview.com/...-measurements-of-orchard-audio-gala-dac.4815/Nice! When can we expect to see those measurements?
